Door squeak and cupholder rattle
Old Feb 9, 2009 | 02:12 PM
jisungoppa's Avatar
Member
Default Door squeak and cupholder rattle
Sorry if this is a repost -- I've tried searching the forum but couldn't find an answer.
When I open my doors, there are really loud creaks coming from the hinges. Does anybody know what the best way to completely get rid of the creaks are?
Also, when it's cold, my cupholders starts to rattle when I'm driving. Is there a fix to this?
Thanks in advance everybody
Old Feb 9, 2009 | 02:20 PM
hcaudikeed's Avatar
Originally Posted by jisungoppa
when i open my doors, there are really loud creaks coming from the hinges. Does anybody know what the best way to completely get rid of the creaks are?
wd-40
Old Feb 9, 2009 | 02:55 PM
jisungoppa's Avatar
Member
EDIT: I went out and bought White Lithium Grease spray and sprayed it on all the hinges. It seems to be working as of now.
Now onto trying to figure out how to get the cup holder rattle away ...
Originally Posted by hcaudikeed
wd-40
Isn't WD-40 not good for painted hinges?
Old Feb 9, 2009 | 04:56 PM
achTTung's Avatar
WD-40 isn't exactly a lubricant. I mean, its got lubricants in it, but its not designed for use like that. The WD actually stands for Water Displacing. The 40 came about because it was the 40th formula they tried. Originally developed in the 50's as a corrosion inhibitor for rockets. It shouldn't hurt a painted hinge though, at least, I've never seen it hurt auto paint like that.
White Lith was the better choice, but sadly, not a permanent fix. My driver door squeaks like crazy every winter. I have to keep respraying it with lithium every couple weeks. No problems in the summer though.
Cup holders... I'd try tightening the screws that holds it in place, and if that doesn't work, loosen it up and stick a little piece of felt under the contact points, then tighten it down.
Screws are under the rubber pads at the base of the cup holders.
Robb87s
Nov 19, 2011 12:19 PM
bakin1
B8 Models
Mar 13, 2009 02:13 PM
aturcotte
May 27, 2008 07:14 AM
wantonsoup
Nov 28, 2007 05:08 PM
newbuyer17
Oct 18, 2007 10:03 AM
