Driver's Side Door Window Does Not Drop Down By 5mm On My Audi TT (Mark 1)
Old May 2, 2016 | 12:46 PM
jjt1234's Avatar
Old May 3, 2016 | 12:43 AM
Mollyz's Avatar
Originally Posted by jjt1234
That means you'll need to take the door panel off, get to the locking mechanism, and replace the micro switch. There are some really good threads either on this forum or the other one (AudiWorld.com). They have pictures and links on where to buy them (ebay (from china). They are cheap and also there are ones for the left door which are different frome the one you need (right door). I think if you look at all my post you'll find the link. Its not a hard job, but you have to go slow. I actually epoxied my swith in place just to make sure it didn't move from its correct position. Works great.
Hey thank you SO much! I've been searching for info on this without much success for a while. I read through the thread you posted and followed some links and this looks doable. I found the part on eBay as well.
My horn and my backup lights don't work either. Do you think those could be a relay or switch as well?
Old May 3, 2016 | 01:09 AM
jjt1234's Avatar
That's an even simpler problem. But I don't wanna hog the limelight. I'll let one of the other "gurus" answer it. Good luck on that door. Just remember.........go slow. And drive that car!!
Old May 8, 2019 | 03:22 PM
Steve Mac's Avatar
Default Worked
Originally Posted by precision tt
did you try resetting it by rolling the window all the way up .then let go of the switch. pull the which up again and hold it for about 5 seconds. let go and open the door to verify the operation worked. try it a couple of times if it does not work right away.
Worked perfect thanks
Old Nov 7, 2023 | 12:01 PM
Soubeyran's Avatar
​​​​​​Many thanks! Worked first time. I think I triggered it by driving off at the weekend with both doors AND the boot not closed properly! Had to stop 3 times...
Graeme
bauer1185
Feb 7, 2010 10:13 PM
CorbyAudiTTOwner
Dec 22, 2008 07:39 PM
4mymalamute
Dec 19, 2008 02:00 PM
Mikefc626
Jun 14, 2008 11:44 AM
diehlryan
Nov 23, 2006 06:14 PM
