Dyno results
Old May 19, 2008 | 02:22 PM
zelpdsm's Avatar
Default Dyno results
Had my car on the dyno on Saturday. Here are the results. Power is about where I expected, but it looks like I am running pretty lean. Car is an 01 225QR. Mods are GIAC X, NGKBPR7E gapped to .028", VTDA, MBC, Forge007 yellow spring. The first run was 21psi. I saw that it was lean so we did the second pull at 18psi. The power dropped, but A/F stayed exactly the same. Third run was the same as second. What could be causing this?I assume those bumps on the graphs are timing being pulled.
[IMG]local://upfiles/43247/359E8BD2539B47CEA08E2F4C85333092.jpg[/IMG]
Old May 19, 2008 | 02:37 PM
cincyTT's Avatar
I'm make believe
Default RE: Dyno results
Having a cat and the a/f being read from the exhaust tip. This causes it to read lean by ~1 full point. Also the stock tuning already runs lean. So if this is what you have and how it was tested, you are fine/normal
Old May 19, 2008 | 02:51 PM
zelpdsm's Avatar
Thanks, any thoughts on the bumpy graphs? Unfortunately we couldn't read timing.
Old May 19, 2008 | 03:04 PM
cincyTT's Avatar
I'm make believe
It is at peak psi and my best guess would bt the n249 opening the dv a little bit. Dont think timing would of been the cause unless you had severe pull which is less likely. Your psi didnt fluctuate at all did it?
Old May 19, 2008 | 03:18 PM
zelpdsm's Avatar
It wasn't jumpy. It does trail off a little asrevs go up though.
Old May 19, 2008 | 03:46 PM
cincyTT's Avatar
I'm make believe
my best guess would still be a n249
broker23
Nov 8, 2013 07:14 PM
The Russian
Nov 7, 2007 01:32 PM
eliTTe
Oct 22, 2007 01:58 PM
daesharacor
Sep 12, 2007 12:16 PM
dan
Jul 6, 2006 08:46 PM
