engine build question
Old Jun 23, 2009 | 11:48 AM
sacgns's Avatar
Default engine build question
with a awp block is a aeb head a direct bolt on or do i need to make modifications? if so wat needs to be done to run it rite
Old Jun 23, 2009 | 06:26 PM
cincyTT's Avatar
I'm make believe
All the 1.8t are interswappable. You just have to use the correct cam tensioner. Also you will lose the sai system. If you are not planning on making 400+ whp, there is no need for a AEB head
Old Jun 24, 2009 | 11:38 AM
sacgns's Avatar
i plan making as much as i can with this it will just take time
Old Jun 24, 2009 | 12:03 PM
jhsoccerodp's Avatar
if money is not an option go ahead and do it, but if it is i think money could be spend a little wiser if you plan on making nearly that much power.
Old Jun 24, 2009 | 04:13 PM
sacgns's Avatar
what would you suggest then?
Old Jun 24, 2009 | 04:19 PM
Water meth, sem intake manifold. A bigger turbo, I would worry about the head so much it will flow enough air to get yourself in trouble enough. Unless its a straight race car, I wouldn't. Butthats just imo, I can send you my build list if you want from when I was looking at doing it. Enough to get 400 wheel.
Old Jun 25, 2009 | 12:00 PM
sacgns's Avatar
ya that be cool thanks my email is sacgns@yahoo.com
Old Jun 25, 2009 | 05:33 PM
cincyTT's Avatar
I'm make believe
HigashiOmok
Nov 12, 2013 01:53 PM
Audisaurus
May 14, 2011 02:33 PM
Nevering
Mar 7, 2011 11:12 PM
nemohm
Apr 19, 2008 11:43 AM
theguy1084
Mar 6, 2007 02:48 PM
