engine coolant
Old Feb 14, 2008 | 08:00 PM
n3371e's Avatar
Default engine coolant
GA_googleFillSlot("Forums_ROS_300x250_noad");
var tcdacmd="sa=a;sz=3;ad";
[/align]
dcmaxversion = 9
dcminversion = 6
Do
On Error Resume Next
plugin = (IsObject(CreateObject("ShockwaveFlash.ShockwaveFl ash." & dcmaxversion & ")))
If plugin = true Then Exit Do
dcmaxversion = dcmaxversion - 1
Loop While dcmaxversion >= dcminversion
hi,
i had my engine coolant fill due to very low amount of fluids and was put in orange fluid instead of pink. would this cause damage to my engine or would you suggest to drain and refill with pink engine coolant G12?
thanks in advance.
big E
Old Feb 14, 2008 | 09:09 PM
Agnt008's Avatar
Default RE: engine coolant
I put about a 1/2 cup of the orange stuff (which i was told by several people never to put into any car because i guess it eats away parts or something) in my Audi and I noticed that it runs about 1 line shy of the half mark now due to it... it sometimes goes up to the 1/2 mark for coolant temp, but since i added in just that little bit it runs cooler. I am going to drain and clean and put in the G12 only. I suggest you do the same!!
Old Feb 15, 2008 | 09:03 PM
achTTung's Avatar
I'll say first off, Universal Coolant isn't universal.
Keep with the G12, it was engineered for the cars, it'll do you good. Your car isn't going to burst into flames or anything by not running G12, but eventually, over time, you'll probalby end up with some pitting and erosion of your coolant system. If you can, run the G12. If you can't right now, do a flush when you CAN get to it.
Old Feb 15, 2008 | 09:14 PM
cincyTT's Avatar
I'm make believe
G12 mixed with other coolent = gel. You really should drain and refill with G12 or G12+. Do not add additives either
redryder011
Apr 20, 2009 03:50 PM
seahawkfan94
Jan 6, 2009 03:17 PM
69Nomad
Nov 26, 2006 04:48 PM
TexasAudi
Jun 29, 2006 12:35 PM
