Engine Sputter at and above 4200 rpm?
Old Apr 21, 2008 | 06:48 PM
michelledw's Avatar
Default Engine Sputter at and above 4200 rpm?
I have a 2001 TT with a Garrett chip and ECS diverter valve among other small mods. I can't figure out what's causing a sputter at 4200 rpm's and above. Has anyone else experienced this? It was first diagnosed as bad ignition coils, replaced those to no avail... then a vacuum hose, again replaced with no change. The problem seems to be getting worse. Any ideas?
Thanks!
Old Apr 21, 2008 | 07:08 PM
randomloginname's Avatar
Default RE: Engine Sputter at and above 4200 rpm?
do you have cold range plugs gapped to 0.028?
Old Apr 21, 2008 | 07:45 PM
cincyTT's Avatar
I'm make believe
^ i would go with no on that one
spark plug info is in the FAQ on top of this forum
Old Apr 21, 2008 | 08:40 PM
ouTTie914's Avatar
ORIGINAL: michelledw
Garrett chip
Found your problem...
Have you gotten a check engine or EPC light yet?
Old Apr 22, 2008 | 09:40 PM
Mobius97's Avatar
ORIGINAL: cincyTT
I 'd go for that as well. When this happened to me, a simple change in the plugs did me well and cleared the issue.
anpm
Mar 11, 2014 12:27 PM
patmandu
Oct 2, 2009 11:25 PM
OneBlackAudi
Oct 3, 2008 12:14 PM
stync
May 15, 2008 12:54 AM
Audiphene
Feb 18, 2008 09:14 PM
