eurojet pcv hose
Old May 29, 2008 | 02:14 PM
theTTkid's Avatar
Default eurojet pcv hose
nice little hose i got in the mail. easy install...
made me realize how much gunk and stuff goes through the system.
cincy, if you dont mind can you post the link for your cheap oil catch can? i looked around and couldnt find it
Old May 29, 2008 | 03:05 PM
cincyTT's Avatar
I'm make believe
Default RE: eurojet pcv hose
Its all available at home depot or lowes.
Husky or Lowes air compressor filter (by the compressors of course)
1/4" double male fitting
1/4" (female) to 1/2" (male) fitting.
90* fitting (if you choose to remove regulator since its not needed)
hose and clamps to connect the parts.
That EJ peice is a nice upgrade for those with AWP engines. Us ATC'ers have hardpipe that makes us not need that peice. We still have problems below it (had to replace some of mine), but that Y peice the EJ replaces goes bad fast.
Old May 29, 2008 | 03:40 PM
moeron7's Avatar
How bout some pics of the pcv hose installed?
Old May 29, 2008 | 06:10 PM
cincyTT's Avatar
I'm make believe
lower portion
Old May 30, 2008 | 08:55 AM
MeanAudiA6's Avatar
that doesnt look like it will fit the AMU engines,,,maybe i need to see that pic from a different angle if it doesn fit
Old May 30, 2008 | 11:32 AM
cincyTT's Avatar
I'm make believe
I will only fit an AWW/AWP engine code
Old May 30, 2008 | 11:33 AM
twenty8red's Avatar
i got mine in the mail yesterday too. it is a nice little piece and cheaper than the oem one. when i was pulling the old one off i broke the connection that goes into the front left side of the y so now i have to fix that. [:@].
Wintermute
Oct 15, 2008 01:39 AM
TheLastNexus
Jun 30, 2008 01:30 PM
TTsteve
Jun 4, 2008 08:05 PM
Euroluv
Feb 4, 2008 05:13 PM
