Evoheatshield Phenolic Spacer?
Old Apr 15, 2007 | 01:48 AM
twenty8red's Avatar
Default Evoheatshield Phenolic Spacer?
Does anyone have any experience (or opinions) with this?
http://www.ttstuff.com/Merchant2/mer...Code=EVO-A4102
Just wondering if it would be beneficial. Thanks.
Old Apr 15, 2007 | 02:33 AM
cincyTT's Avatar
I'm make believe
Default RE: Evoheatshield Phenolic Spacer?
Several have them, check out steve schwing's fotki page on his modshack site. He has a couple graphs to show a differness
Old Apr 15, 2007 | 03:01 AM
XCLR8TT's Avatar
I have one. That and a FMIC will keep intaked temps low.
Old Apr 15, 2007 | 03:10 AM
twenty8red's Avatar
thanks for the info. will i see any performance gains from just this? i will be installing a fmic in the future but can just do one now.
Old Apr 15, 2007 | 03:24 AM
cincyTT's Avatar
I'm make believe
Not much, you may get a degree or two of timing back that a heatsoaked intercooler would rob.
Old Apr 15, 2007 | 05:57 AM
225tt's Avatar
I have one, it will show good gains with a FMIC and stuff like water injection. I think that for the little amount of money that it is, its worth it. But that is just my 0.02.
Old Apr 15, 2007 | 02:31 PM
achTTung's Avatar
Its on my long list of things to make for the car.
Hmmm... should probably get on that.
Old Apr 15, 2007 | 03:01 PM
MeanAudiA6's Avatar
i'll be ordering one here for the summer Also a handy tool for tuners is a infrared Thermometer from radioshack 49.99 part number is 220.0325 reads temps 0-400 degrees F i noticed a pretty big difference in the readings on the intake manifold after installing my APR FMIC also 225tt did you have to dremel to make the gasket fit? i would hate to get shavings into the valve train....even with plugging the ports and then using a vaccum to suck up the shavings lol
Old Apr 16, 2007 | 09:00 AM
225tt's Avatar
Yep, used the dremmel to match it all up. I did end up sticking some stuff (paper towels and clean rags) into the intake ports then gave it a good shot with the air compressor to make sure everything was cleaned out. Let me know how yours turns out.
ericp1.8T
Mar 13, 2010 02:32 PM
keefboz
Apr 13, 2009 05:27 PM
jakgtrey
May 9, 2008 10:02 AM
A4speed
Mar 23, 2008 02:37 AM
zectasy
Jun 10, 2007 09:51 PM
