Exhaust leak
Old Sep 14, 2009 | 05:25 PM
penguinpete's Avatar
Default Exhaust leak
If I start my car when it is cold I get an exhaust rumble coming from under the hood but it goes away after less than one minute and the car has to cool down for several hours before the exhaust noise comes back. I brought it into the local shop (German Motor Works) and they were not able to find the leak, they recommend that I bring it to the local dealer. Has anyone had a similar problem and what fixed it?
Old Sep 14, 2009 | 07:50 PM
cincyTT's Avatar
I'm make believe
Wait for your car to be cool and start up the car and just run your hands over the exh system. Best places to look are at the turbo to manifold and around the flex section of the dp. The gasket and flex section both have known to cause issues.
Old Sep 23, 2009 | 02:01 PM
carhopper's Avatar
It is likely your secondary air injection system. This is normal. It basically opens up the exhaust and pumps it into the air intake to recirculate exhaust gas during a cold start. You should be able to hear the noise coming from the air filter. There is a black hose on the passenger side of the air box, remove it and plug it with your finger and the noise stops. Personally I hate the noise, but haven't invested any time in removing the system.
Octane567
Aug 8, 2014 10:28 AM
Eric_C
Aug 21, 2010 10:40 AM
mikeeboy82
Jun 13, 2009 11:09 PM
Quattro_1.8t
Nov 18, 2008 01:16 AM
BBA4
Nov 19, 2006 12:43 AM
