Exhaust Problem
Old Dec 12, 2007 | 03:20 PM
cincyTT's Avatar
I'm make believe
Default RE: Exhaust Problem
it will. Just need the right end section to connect to the exhaust. When you get a new one, you will need a differnt end peice.
Old Dec 12, 2007 | 03:26 PM
TurboToughTT's Avatar
If the rest of my car is stock I should get the stock cat-back adaptor right? cause the site ask what size i need sotck 2.5 or 3. i know im asking alot of questions i just dont want to get the wrong part
Old Dec 12, 2007 | 03:35 PM
cincyTT's Avatar
I'm make believe
Yes you want the stock. I still think you should get the ebay dp and when the time comes for a larger exhaust, you can get the 42dd cat or tp with the larger end fitting. Should save you $100-150 in the long run
Old Dec 12, 2007 | 03:41 PM
the 42DD will give me performance to Right?
Old Dec 12, 2007 | 03:49 PM
cincyTT's Avatar
I'm make believe
both will give the same perfomance. its just a welded pipe
Old Dec 12, 2007 | 10:57 PM
Im ordering the Ebay piece I just need that and it should fit right on Right?????
Old Dec 12, 2007 | 11:05 PM
cincyTT's Avatar
I'm make believe
mine did. No fitment issues at all. But dont use the gaskets that come with it (or any for that matter) and either get new oem bolts of reuse yours. And remember, use plenty of PB BLaster and let it sit for an hour before you try to remove the dp
Old Dec 12, 2007 | 11:11 PM
  #18
2000auditt's Avatar
whichDp would work for mine 2000 quattro
Old Dec 12, 2007 | 11:13 PM
  #19
2000auditt's Avatar
i mine the 180 quattro
Old Dec 12, 2007 | 11:16 PM
  #20
Great thanks fro the help I purchased it does it get louder? Quicker?
