Exhaust Problem
Old Dec 12, 2007 | 02:36 PM
TurboToughTT's Avatar
Default Exhaust Problem
I was driving today and i heard a nice pop. I didnt no what it was i took it to a guy i no at a shop he said my flew pipe broke. thats the Dp right? they want 230 to fix it. u think i should jsut spend an other 20 or 300 and get a exhaust or just fix it. i found this on ebay it is good enough?
http://cgi.ebay.com/ebaymotors/99-04...QQcmdZViewItem
Old Dec 12, 2007 | 02:40 PM
theTTkid's Avatar
Default RE: Exhaust Problem
i think that works of you have FWD... i know that doesnt work with quattro...
Old Dec 12, 2007 | 02:45 PM
yeah its a 180 fwd, if i buy a cat. back would it connect to that and i would be good or would i need more
Old Dec 12, 2007 | 02:50 PM
cincyTT's Avatar
I'm make believe
Thats made to fit the stock exhaust. You can either just cut the correct step down and insert a pipe or go to 42dd and get a cat with the correct size fitting or their tp also.
Old Dec 12, 2007 | 02:53 PM
i thought the 42DD was for the quad.?
Old Dec 12, 2007 | 02:56 PM
cincyTT's Avatar
I'm make believe
No, they had fwd dp's also
This is the parts im refering to
[align=center][/align]
or
[align=center][/align][align=center][/align][align=center]with the correct[/align][align=center][/align][align=center][/align][align=center][/align][align=center][/align]
Old Dec 12, 2007 | 03:03 PM
Do u no how much that would be? Do you think i should just do that or go with that and a catback?
Old Dec 12, 2007 | 03:08 PM
when i click on the 180 Dp it goes to the 225
Old Dec 12, 2007 | 03:12 PM
cincyTT's Avatar
I'm make believe
Cause you probably need to go to the MKIV stuff http://42draftdesigns.com/categories...8tdownpipe.htm
The difference between the cat and race is $75. It should be around $100 for the cat and end peice. But if you dont need a cat, i would just cut the ebay dp at either 3" or 2.5" to match up with the new catback and just add a pipe and o2 bung and another exhaust sleeve. Be a little cheaper.
Old Dec 12, 2007 | 03:15 PM
http://www.42draftdesigns.com/catego...8tdownpipe.htm
if i just buy this will that be all i need?
