Fan Switch Location?
Old Jul 18, 2011 | 11:41 AM
pravn's Avatar
Originally Posted by EdgarPerez4569
The New Fan Switch Didnt fix the problem Fans Still Dont Turn ON, but i notice if i take out the #16 Fuse in the panel door The Fans Come ON! I've Tried that before and they never Turn ON but now they do how weird..
any clue what my issue could be?
#16 fuse is for water pump and magnetic clutch. test your fuses with Ohm meter. May be there is a wiring connect problem.
Old Jul 19, 2011 | 05:58 AM
EdgarPerez4569's Avatar
how do i check the fuses with a ohm meter, disconnect batter? the meter should read 0 ohms? i think i have an idea.. i replace the Fan Switch, Fan Module with my Wifes Beetle, it was the same part number so i use that one, the fans never come ON unless I Remove the #16 Fuse. and they turn one at one Speed only so the Car still overheats after like 7mins at Idle. the #16 fuse has battery voltage at one of the testing point and the other doesnt have any voltage. my brothers car but im tryin to fix it. the car is being sitting there for over a month now, but i seriously dont know what could it be.
Old Nov 6, 2012 | 03:37 PM
skyhighhobby's Avatar
im trying to find my fan switch for my audi tt 2002
here is a picture, is this it? if so, how do i disconnect it and do i need to flush coolant or its electrical?
any help would be appreciated.
Old Feb 15, 2013 | 08:58 PM
magarmuch's Avatar
I know its been a few years since your post, but I am pacing the same problems and hoping for some guidance on how to fix it. The large fan does not come on. What could be the problem? fan itself or the Control Module? Thanks
Old Feb 16, 2013 | 02:50 PM
if this will help anyone, my issue ended up being the water pump, so from the beginning, my pump went out, i drove home slowly as car was over heating, so what happened was due to the car overheating ( as i drove it home ) a domino affect took place, first my thermostat closed shut, then that triggered my fan switch and that went bad as my fans were not turning. ended up getting a new water pump, new fan switch and new thermostat, car works fine now.
Old Feb 16, 2013 | 08:08 PM
magarmuch's Avatar
Fan control module location under the battery.
phatjames167
Jul 22, 2013 12:58 PM
quicknick
Sep 1, 2011 10:20 AM
Iniquite
Aug 31, 2010 09:55 PM
ezlnh8u
Oct 20, 2007 03:20 PM
lidonnit
Jul 10, 2005 04:40 PM
