Fans not coming on
Old Jun 22, 2011 | 01:02 AM
Whitr's Avatar
Default Fans not coming on
I have a 2002 225TT Quatro and the two fans are not coming on. My temp gauge reads normal even in traffic in 95 degree weather, which really seems odd. A/C is not cooling very effectively, but it is cooling some. Any ideas where to start? Thanks
Old Jun 22, 2011 | 11:54 AM
coachvtt's Avatar
Fan switch prt # 1J0-959-481A
Green temp sender prt #059-919-501A
Are your fans coming on at all?
I had to change the larger one...Good Luck
temp sender diy..search
Old Jun 23, 2011 | 10:03 AM
Whitr's Avatar
Thanks for the quick response coach. Neither fan is coming on and yet I am not overheating in 95 degree weather. I find this strange. I have let motor run at idle w/ac on for 20 mins. and no fans. I'll look at the diy site you referenced. Thanks again.
Whit
Old Jun 24, 2011 | 09:19 AM
coachvtt's Avatar
Not overheating! not sure what temp our cars make it too overheat. but check the fuse to your temp gauge! Fans not on during the A/C thats weird and not overheating!!Hmm
and Do you have a thermostat in? Turn the heater on and see if your getting heat?
If not no thermo. Get the Vag-Com or OBD II scanner and just check and see what you get!
I'm just trying to eliminate things, stay away from the stealership...$$$$
Maybe someone else can shed some light on this!
corrado33
May 27, 2015 09:30 AM
madfam
Oct 16, 2014 06:38 PM
pye
Jul 18, 2011 11:12 PM
IPStevieB
Apr 8, 2010 01:23 PM
sabroker
Mar 5, 2007 12:24 AM
