Fender removal 2008 TT
Old Dec 14, 2014 | 02:09 PM
TT Dreamer's Avatar
Default Fender removal 2008 TT
Hello,
I'm trying to remove my left front fender but I'm stuck. I have the wheel well liner almost removed but there's one spot where it is attached under the side skirt and I don't have a clue how to remove the clip that's holding the side skirt. Anybody any Ideas? Thanks.
Attached Thumbnails Fender removal 2008 TT-imag0705.jpg   Fender removal 2008 TT-imag0709.jpg
Old Dec 14, 2014 | 07:24 PM
Lt1 Burb's Avatar
Aren't those just the plastic clips, try popping it up with a small screwdriver.
Old Dec 15, 2014 | 07:36 PM
Mk1-996/8N's Avatar
that's what I was thinking too...if it feels like plastic, try pop it off as mention
Old Dec 16, 2014 | 02:20 PM
TT Dreamer's Avatar
I tried to get a screwdriver in between and pop them out as suggested but that's not working.
Old Dec 17, 2014 | 02:08 PM
TT Dreamer's Avatar
Quick update: After messing around with the clip for a while I managed to get it out. As suggested, it popped right out and I removed the wheel liner. Now, do I need to remove the skirt in order to remove the fender?
Old Dec 23, 2014 | 01:57 PM
bSkogheim's Avatar
Yes, there are two bolts under the front of the rocker panel/side skirt. Careful removing the side skirt. You may want to get some replacement clips for it ahead of time as at least one or two will likely break.
Old Dec 26, 2014 | 11:47 AM
TT Dreamer's Avatar
Thank you for the information.
sdsteez
Sep 26, 2010 10:20 PM
96-A4-2.8-Quattro-PearlWhite
Jul 17, 2010 09:37 PM
flynnr
Dec 6, 2008 12:12 AM
TG
Jul 5, 2008 11:14 AM
fullboostin
Jun 6, 2006 02:14 PM
