Fighting to get the TT up to Par
Glad i could help, now send me your tranny!!!
As for the wbo2, you can do 1 of 2 things. 1) you can just install the wbo2 w/ sensor (you will need a new bung welded in) and nothing will be run to the ecu or 2) swap to a awp ecu and have the wbo2 sensor control the a/f instead of the nbo2 (what i plan on doing). The second option will also give you access to a better tune with a larger turbo.
Like i said, i wish i had the money for it. You should hold on to it until i do
The ecu will take some work, but worth it. There are several ecu swap threads on vortex if you want to see whats all involved.
everything takes works[&:]
oh and i cn hold the tranny if you want. im in no rush to sell it anyways. but i got the 6spd tranny @ a crazy price so i had to act fast
can you throw me a link on the ecu topic by any chance nate?
i was thinking about a WB02 controller ... something like this or that
also can a A/F controller do the same ?
all you need to do is search the 1.8t archives for "ecu swap." You will already have a factory wb installed with the ecu swap so you can either just get a vagcom to run logs and tune with lemmi/unisettings or get a gauge and tap into the wbo2 so you have constant a/f monitoring.
I would love to take that o2m off you hands when i get a chance to drop the funds.
Adaptation would change the settings and not allow you to use lemmiwinks from what i have heard. Innovite makes good wbo2 stuff, but you really just need a stock sensor and a vagcom cable
hey i was reading a search on the innovative WB02 i got this from tex
"quote from manual:
It is possible to install the wide-band sensor in place of the OEM oxygen sensor. In this case the
meter's analog output signal will replace the OEM oxygen sensor's signal to the fuel injection
computer. EFI equipped cars typically incorporate a narrow band oxygen sensor. These sensors
are typically 1, 2, 3 or 4 wire sensors.
The analog output connector of the LC-1 can simulate the operation of a narrow band sensor
while the wide-band oxygen sensor is installed in place of the OEM narrow-band sensor. Factory
equipped Analog output 1 of the LC-1 is programmed to simulate a narrow band sensor. Some
vehicles are equipped with oxygen sensors that do not produce an output voltage but change
their resistance depending on exhaust gas content. These sensors cannot be simulated. They
are used in less than 1% of all vehicles. Refer to your vehicles specifications if you think that
your vehicle may be in this category. The same is true for vehicles already factory equipped with
a wide-band oxygen sensor. These cannot be simulated either.
Some EFI-computers will create a fault when the heater power wires of the oxygen sensor are
disconnected. In this case mount the old oxygen sensor in a safe place (but not necessarily in the
exhaust) and connect the heater wires to it to keep the EFI-computer happy."
"quote from manual:
