figure this one out
Old Apr 19, 2010 | 11:59 PM
wezal's Avatar
Default figure this one out
So I had to get a new stater..6 speed quattro, you guys know the spec's. So my father takes the starter out and goes to order a new one for a 6 speed 1.8q 2001. The stater comes in and my dad and I pre fitted it and nothing is lining up so he takes it back to the parts store goes to a warehouse to get another one. Brings it home fits it and nothing lines up on the block, again, mind you he did order the 6 speed manual gear box starter. So doing he checked the part number on the starter and looks it up. turns out it is a starter from a audi tt automatic. transmission totally different from a 6 speed manual tranny, how is this possible? dose anyone know why an automatic starter would turn the crank on a 6 speed? if you look at a 6 speed trany stater and a auto they are totally different? By the way this is the original starter that came with the car!!! Any suggestions anyone.....
Old Apr 20, 2010 | 05:33 AM
fly200's Avatar
Post
I think all TT automatic trannys are 5 speed, that would be your answer If im correct and I believe the Audi 225hp Quattros are all 6 speed, so they are not the same.... Someone else correct me if im wrong here....
Old Apr 20, 2010 | 08:13 AM
beachchair's Avatar
You are......
The starter on a manual transmission mates with a flywheel. Automatic transmissions have no flywheel so in most cases, the starter lines up completely different.
Old Apr 20, 2010 | 11:35 AM
cincyTT's Avatar
I'm make believe
You need the one for an 02M. If they cant get the correct one for your car, tell them you have a VW GLI with a 6sp
Old Apr 21, 2010 | 09:04 PM
wezal's Avatar
Thanks Cincy. DO you think this is something that they changed on the production line. I mean how the heck can I have an automatic stater on my car? NONE of the manual starters are fitting. I'am waiting on a new one that should be here by tomorrow so we will see if not ill try what you suggested.
Old Apr 21, 2010 | 09:58 PM
cincyTT's Avatar
I'm make believe
Nothing has changed. There is a auto, 02J (fwd 5sp), and 02M (AWD TT models and 6sp VW models). Most times you get a 02J starter when you need a 02M.
Loquito14
Oct 4, 2016 09:07 AM
jason955
Oct 18, 2009 11:10 PM
USAF29
Jun 18, 2008 09:15 PM
nickellis14
Jun 3, 2008 02:00 PM
sljone
May 24, 2007 09:15 AM
