FMIC Problems....Pretty bad I think! HELP!
Problem SOLVED!!!
--Turns out to be another failed Coil-pack. I just replaced a pack last week and so I was too quick to rule that out. I replaced cylinder#4 and cylinder#1 went out in the process aparently... lame, but at least it's a quick fix!!! My pipping is all fine to the intercooler.
thanks for the help
thanks for the help
let me know how much pressure drop u get from running the fmic like that. i was worried about it like that due to all the extra piping. i had a big thread going about it, which is where u grabbed the image i imagine.
Also if you havent already, go ahead and replace the other coil packs jsut to be on the safe side. If something caused the other two to go bad then the others may be on their way too.
ORIGINAL: TTsteve
ORIGINAL: 225tt
Good question...anyone know why?
ORIGINAL: theTTkid
why would a coilpack lead to "smoking/burning/fumes"
But if you have a good seal the turbo shouldnt smoke, all that unburnt fuel would just go out the back of your exhaust, unless there is something that I am missing. I know turbos smoke when you put or spill stuff on them ie: oil, brake cleaner, WD-40 stuff like that. I dunno...
