FMIC question
Old Apr 30, 2007 | 12:26 PM
TTsteve's Avatar
Default FMIC question
Looking at FMICs and all I see something about map sensors. My question is when I went to the APR FMIC would I need to change my map sensor? I would assume that I am flowing more air into the intake mani now with the bigger piping and IC? My car is running good and all but when looking at the BF SMIC it said you might have to get a biiger map sensor, is that true with FMICs too? Thanks.
Old Apr 30, 2007 | 01:33 PM
cincyTT's Avatar
I'm make believe
Default RE: FMIC question
They are both factory map's, one just needs a larger hole than the other. They both do the same thing and read the same, one just need a larger hole for fitting.
Old Apr 30, 2007 | 04:42 PM
TTsteve's Avatar
Cool sounds good, thanks. Im also researching the things Im going to do to the new TT. Im not going to get the mod bug as bad on this one, just keep it simple but a little faster. Chip, full exhaust, CAI, better flowing hoses in key areas and maybe upgraded SMIC.
Old Apr 30, 2007 | 04:45 PM
cincyTT's Avatar
I'm make believe
the 2.0t's have a fmic, atleast the gti's do.
Old Apr 30, 2007 | 04:54 PM
TTsteve's Avatar
Hmmmmm Ive been trying to find something on the internet that would talk about the new TT turbo and IC but couldnt find anything. But if it does come with a FMIC then all the better.
Old Apr 30, 2007 | 05:04 PM
cincyTT's Avatar
I'm make believe
more info here
Old Apr 30, 2007 | 05:32 PM
TTsteve's Avatar
Damn that is a huge FMIC. I wonder what the effeicency numbers are? So it would probably be safe to say that even with a chipped 2.0T that FMIC should do the trick. But it does make me curious as to why they went away from the SMIC or even the dual SMIC for a stock 2.0T. Did they raise the boost on this new car real high to get that extra HP? Good info thanks.
Old Apr 30, 2007 | 05:52 PM
cincyTT's Avatar
I'm make believe
there is a vag chart in the link, seems to be very effective on a tdi and on mkiv cars. The boost should be about the same, you get the extra hp from extra displacement and i think they run 10:1 compression also.
Old Apr 30, 2007 | 07:56 PM
Creepin's Avatar
I'm going to be running the boostfactory smic and an smc alcohol kit. Should be wayyyyyyy more then enough for what i'm looking for. Few more weeks...
Paul1234
Dec 22, 2012 03:25 PM
twenty8red
Jul 27, 2007 11:21 AM
Mya4T
Jun 15, 2007 09:49 AM
Audi4Brett
Jun 5, 2007 01:08 AM
prodrive
Oct 1, 2005 04:16 PM
