forge 007 spring
Old May 7, 2007 | 04:24 PM
randomloginname's Avatar
Default forge 007 spring
just got in the forge 007 piston dv, hoping it will solve my lost boost issue. got it from ttstuff so it came with a couple shims and the blue and yellow springs. i am unchipped, so can I just use whatever the default spring in there is? thanks
Old May 7, 2007 | 04:33 PM
TSRgeneral's Avatar
Default RE: forge 007 spring
Yes, I believe that the stock spring in there is the red one. That is the best spring for unchipped cars. After you get it chipped a shim should do the trick. Im not sure what PSI the other springs are set for.
Old May 7, 2007 | 04:43 PM
cincyTT's Avatar
I'm make believe
yellow is the chipped spring.
Old May 7, 2007 | 06:22 PM
MeanAudiA6's Avatar
green is the stock spring! yellow with one shim is what i run...i might try 2 shims next
Old May 7, 2007 | 09:11 PM
achTTung's Avatar
the 180 was running a green spring, 2 shims, on the APR 93oct. chip.
Old May 8, 2007 | 02:02 AM
Default missing boost/forge 007
i replaced the dv because i wasnt getting the boost i expected to see, i have an 01 225q and am only seeing it hold 5psi and spike to 10-11psi. the forge dv def made some difference in spool time and boost recovery, but it didnt change the max boost i saw, so i assume i have a leak somewhere. i know i couldve flipped the bosch dv(thanks cicny) but i know i want to chip it later so i replaced the dv anyways in case that was the issue, apparently its not. i dont have a compressor so i dont know that ican check for leaks that way, other reccomendations? thanks.
Old May 8, 2007 | 09:02 PM
achTTung's Avatar
Default RE: missing boost/forge 007
buy/build a pressure tester, and take it somewhere that does have a compressor.
hell, a gas station would work...
Old May 9, 2007 | 04:57 AM
I just swapped the green (one it shipped with installed) for the yellow no shims, and it definitely helped, it still wont go over 10-11 psi, but it will hold there under WOT and keep 7psi when it was giving me 5 before. Would like to get the APR 93 after I get the strut bearing/bushings replaced, if this boost situation sounds normal for an unchipped 225.
Old May 9, 2007 | 07:55 PM
achTTung's Avatar
That sounds low for a 225. Pretty sure you should be 3-5psi higher. I don't currently have a boost gauge, so I can't tell you definate readings, but the numbers you're posting are as low, or lower than I remember for my 180 before it was chipped.
Old May 9, 2007 | 11:30 PM
MeanAudiA6's Avatar
those numbers are correct for the stock 225
