Forge -DV- Tune Up Springs
Old Mar 13, 2008 | 01:52 AM
  #31
hotgrass's Avatar
Default RE: Forge -DV- Tune Up Springs
its weird since i took my car to one of the apr installers to check if i had a chip and they said that there is no chip. i dont think i have diodes either. it is currently holding to 18 psi. im using a green spring with 2 shims. you guys said that normally, 225 should be at 14 or so psi and i have 18?
Old Mar 13, 2008 | 07:33 AM
  #32
randomloginname's Avatar
You might want to check to make sure you are dumping that boost when you are supposed to to ensure you dont damage anything, and double check you are measuring boost at the approriate location. I guess you could also doulbe check which n75 valve you ahve and make sure it is plugged in.
Old Mar 13, 2008 | 07:52 AM
  #33
beachchair's Avatar
ORIGINAL: randomloginname
Good point.
Unfortunately too much boost can be harmful. I'm surprised the APR installer you went to didn't do any further checking. Whatever the situation, holding that much boost is unusual.
Old Mar 13, 2008 | 11:54 AM
  #34
cincyTT's Avatar
I'm make believe
You are most likely flashed by someone else. Also having the green spring (with or w/o shims) cant harm anything. It is no where near as stiff enough.
Old Apr 7, 2008 | 02:21 PM
  #35
hotgrass's Avatar
ok, so when i start the car, im at 14-15 psi, then when i drive around and park the car, im at 18 psi. does it mean im chipped?
Old Apr 7, 2008 | 03:03 PM
  #36
cincyTT's Avatar
I'm make believe
Sounds like you are talking about vacuum (in hg) and not psi.
Old Apr 8, 2008 | 11:39 AM
  #37
hotgrass's Avatar
what does that mean? is that normal cincy?
Old Apr 8, 2008 | 12:32 PM
  #38
cincyTT's Avatar
I'm make believe
If we are talking vacuum, then yes, its normal.
foxracing4500
Mar 20, 2011 01:47 PM
MeanAudiA6
Oct 1, 2007 09:22 PM
MeanAudiA6
Sep 23, 2007 07:26 PM
S4evr
Dec 8, 2006 08:02 PM
germancarmaniac
Jun 23, 2006 01:52 AM
