FS: EFU 4U (boost,oil,tach gauge)
Old Aug 5, 2007 | 10:10 PM
TSRgeneral's Avatar
Default FS: EFU 4U (boost,oil,tach gauge)
So after more than a month trying to get the EFU to work in my car i have given up. The unit is incompatible with my car. I wish it worked but it seems that my radio and EFU are not able to link up and tranfer information. It will work with any other car except for mine. Installation was a breeze and the unit is small. If you dont know what the EFU unit is check it out at http://techreactions.com/
So i am selling the unit, which is in like brand new condition with all the wires and harness. It has the v1 program as well as a boost gauge, oil temp sensor, voltmeter. I paid $374.00 USD and want $325 plus shipping
Old Aug 5, 2007 | 10:29 PM
achTTung's Avatar
Default RE: FS: EFU 4U (boost,oil,tach gauge)
highly interested!
Whats the issue with your car? Is it something I'd be able to check with mine before a deal was made?
Old Aug 6, 2007 | 01:57 PM
TSRgeneral's Avatar
Well Im sure you can. Its not a problem with my make or model, it is my specific car. I believe that the harness that the radio connect to in my car is chopped or spilt. I will contact techreactions to make sure they provide warrenty and support for the buyer as the unit has not worked for me.
to check if your car's wiring harrness is untouched take out your radio and see if everything is ok. Thats the best idea I have for checking to see if your car is fine. Im going to be jeleous to see someone else using the EFU as it didnt work for me
Old Aug 6, 2007 | 05:21 PM
achTTung's Avatar
You should only need the harness to the radio if you want data capability on the radio display I thought?
"Stock radio is not required for the EFU to function." - from the techreaction site.
You'd know your car better than I would, but you're sure thats the problem?
Old Aug 6, 2007 | 11:50 PM
TSRgeneral's Avatar
No. Thats the thing I cant seem to figure out the problem. If i did find the problem, then the EFU unit would still be in my car. This is my second unit. Techreaction's support rep said that the unit could be defective. I sent it back to them and they sent me a brand new unit. I had the same problem with the second unit.
Old Aug 7, 2007 | 09:53 AM
ouTTie914's Avatar
What year is your TT?
Old Aug 8, 2007 | 11:44 AM
TSRgeneral's Avatar
2000 ATC
Old Aug 8, 2007 | 06:49 PM
ouTTie914's Avatar
This might be a PITA question but... Could you post up the install directions.
Maybe someone could help figure out your problem, and/or a potential buyer (hint hint) could make a better decision in regards to purchasing.
Old Aug 8, 2007 | 07:20 PM
rayveedub's Avatar
this will not work on can-bus cars. thats can-bus not cannibus, so stoners it wont matter. also acttung, i guess ill be at h20 this year.
CMoriart
Mar 22, 2011 09:05 PM
slackerscott04
11
Feb 21, 2007 04:46 PM
Soley4pres
Jan 31, 2007 04:08 AM
a4bsix
Jul 6, 2006 04:28 PM
s4me
May 18, 2005 08:39 PM
