Fuel Filler flap release switch
Old Jun 6, 2005 | 10:15 PM
tomcat944's Avatar
Default Fuel Filler flap release switch
2001 TT Quat Roadster- FFFRSwitch when pressed will not open the Fuel Filler Flap, must do so manually inside the trunk.
Any suggestions as to how to fix would be greatly appreciated.
Checked all the fuses, all ok. Next?
Old May 15, 2006 | 09:12 PM
Gand1's Avatar
Default RE: Fuel Filler flap release switch
Hopefully someone else will know this. Mine won't work either but neither does the trunk release. I must do that with the key fob. The interior sensor switch still works though!
Help
Confused
Old May 15, 2006 | 09:58 PM
trnc's Avatar
This might sound weird but try locking/unlocking your car a few times.. I had the same problem and somehow unlocking it fixed it???
Old May 15, 2006 | 10:46 PM
Gand1's Avatar
Wow!!! That was it!! I think I've got it figured out though now. It seems I was playing with the windows with the key when you lock and unlock the door. In the end of my playing I left things locked. After that I only used the fob remote to unlock the doors. It seems when you use the key it locks out the trunk and the fuel flap but the remote will not unlock them. You need the key to unlock them.
Mystery solved!!!
Thank you!
No longer confused......
Old Feb 29, 2008 | 04:41 PM
fliflet's Avatar
My 98 A4's fuel door is stuck, as many others have written. Is there a way of unlocking it without manually pulling it out through the trunk? I lock and unlock the from the front drivers side door, and cannot unlock the back two doors as well as the fuel door! Any help?
thx
Old Feb 29, 2008 | 05:09 PM
eliTTe's Avatar
same exact thing happened to me awhile ago, it fixed itself after a couple days
Old Mar 1, 2008 | 01:23 PM
Mobius97's Avatar
This happened to me as well last summer. I used the method above, unlocking/locking the car manually, and all went back to normal.
Old Mar 1, 2008 | 06:09 PM
Red_sapphire89's Avatar
mine freezes stuck when it snows or rains then freezes overnight i have to pry it up carefully not to leave a mark
Old Mar 1, 2008 | 11:52 PM
Agnt008's Avatar
The emergency switch is right under the gas cap in the trunk through what looks to be a vent behind the taillight... it's in the owners manual that I came across yesterday.. so if it's not working.. u can manually do that.
Old Sep 17, 2012 | 05:02 PM
Torro's Avatar
Followed the instructions of using the key to lock and unlock the buttons now work
