Fuel level Sensor or Cluster?
Old 10-19-2018, 12:57 PM
Luka Modric Luka's Avatar
Originally Posted by Mshuaib
Which set of fuses? And where are they located?
Much Appreciated! I have the same issue with my MK1 2001 225 TT
fuel pump sensor is #28
audi tt 2000 1.8 fwd
Old 10-19-2018, 01:12 PM
Originally Posted by Jeremyeccles
Reviving an old thread because I found it first before I found a solution. In case anyone else ends up here looking for a solution to the issue of the fuel gauge always showing full here it is:
1. Pull the fuse for the fuel pump.
2. Turn the ignition key to on (without starting the car).
3. Turn the ignition off.
4. Put back the fuse for the fuel pump.
This will reset the computer, and you should have a fully functioning fuel gauge again.
For what it's worth, this happened to me when I accidentally pulled the fuel pump fuse instead of a different fuse that needed replacing. I put back the fuel pump fuse without turning the ignition on and off, and it somehow confused the computer responsible for reporting the fuel level.
I tried this and didn't work for me. I think I have a different problem
I have 00771 code fuel level sensor (G) short circuit to earth. Im just not sure where to start and how to do it.
mnorm757
B7 Models
05-11-2011 04:00 PM
VaTTer
01-21-2008 04:01 AM
randomloginname
01-10-2007 09:03 PM
Inimical
06-25-2006 10:49 AM
GOGIRL
11-23-2004 06:39 PM
Quick Reply: Fuel level Sensor or Cluster?
