fuel pump noise?
Old Nov 13, 2008 | 10:04 AM
warranty225cpe's Avatar
Default fuel pump noise?
so I'm hearing some noise from the back end of the car. It's a kinda intermitent "thunk" "thunk" noise. I'm thinking it's fuel pump because of the type of noise and location. It almost sounds like an old school retractable antenna. Anyone else hear this from the drivers seat?
Old Nov 13, 2008 | 10:51 AM
Mikefc626's Avatar
I hear it alot. I think it's common with Mk1 TT. I asked about on here when I first got mine.
Old Nov 13, 2008 | 11:22 AM
randomloginname's Avatar
Yup I have had on both my TT's, never any issue beyond the intermittent sound
Old Nov 13, 2008 | 12:12 PM
shkenned's Avatar
What WOULD be symptoms of a fuel pump going out?
Old Nov 13, 2008 | 01:36 PM
cincyTT's Avatar
I'm make believe
trouble starting would be the most noticable.
Old Nov 13, 2008 | 01:43 PM
shkenned's Avatar
Trouble starting as in not attempting to start but never turning over completely, or turning the key and getting nothing at all and no attempt to start?
Old Nov 13, 2008 | 01:45 PM
cincyTT's Avatar
I'm make believe
There wount be enough fuel pressure to start the car. If it was dying, it may take longer to turn over, then not after a while
havent seen to many pumps die. the only one i know that did was murder's since he ran out of gas.
Old Nov 13, 2008 | 04:42 PM
Mikefc626's Avatar
....guess i need to stop running my gas tank nearly empty every time.
i knew it had the possibility to damage the cats, but not the pump
Old Nov 13, 2008 | 07:41 PM
achTTung's Avatar
the fuel surrounding the pump keeps it cool. constantly running your car near empty lets the pump get hot, and CAN cause it to **** out on you eventually.
intermittent clunks are more likely to be fuel sloshing against/around the pump/sender(s).
Do you usually notice it immediately after you come to a stop?
Old Nov 13, 2008 | 10:39 PM
cincyTT's Avatar
I'm make believe
How the hell can it effect your cat(s)? Your a/f and egt dont change depending on how much gas you have left....
