Fuel pump upgrade
Old Oct 21, 2007 | 09:03 PM
TTsteve's Avatar
Default Fuel pump upgrade
If I was to upgrade to a better (Im assuming bigger too) fuel pump would that require a change in my chip tuning or can I just put it in and go? Im reading the the 2.0 has a bit of a small fuel pump and upgrading can add some good hp in the low and mid range. But APR is saying that you need their chip to go along with it. Would the GIAC chip I have be good or does it even needed to be added in the chip? Thanks.
Old Oct 21, 2007 | 09:14 PM
cincyTT's Avatar
I'm make believe
Default RE: Fuel pump upgrade
Adding a fuel pump wont gain you anything. Also changing your fuel pump wont need a tuning change either. Fuel is regulated by the fpr and injectors.
Old Oct 21, 2007 | 09:24 PM
TTsteve's Avatar
APR is saying that the stock pump is low pressure and cant supply enough fuel for modded cars and that their high pressure pump will give the car the fuel it needs compared to the stock one. SO Im guessing they are just trying to sell some BS.?
Old Oct 21, 2007 | 09:27 PM
cincyTT's Avatar
I'm make believe
Maybe a little BS, post a link so i can read it. But if you do need a higher rate fuel pump, a walbro 255lph inline or even a drop in will cost $100 on ebay and supply enough fuel for 500hp.
Old Oct 21, 2007 | 10:25 PM
TTsteve's Avatar
http://www.goapr.com/Audi/products/fsi_fuel_pump.html
Here is the link and thanks for the info. Im not sure if the new TT needs a better fuel pump with a chip or not. Theres not much out there right now on the car.
Old Oct 21, 2007 | 10:26 PM
TTsteve's Avatar
Plus I am thinkning of putting in a MBC for a litle more boost too, so was wondering if I needed a better pump.
Old Oct 21, 2007 | 10:45 PM
cincyTT's Avatar
I'm make believe
Thats an interesting read. should be fine with a chip and other bolt ons. But if you do upgrade, walbro255lph inline pump is the way to go and not the APR
Old Oct 21, 2007 | 10:46 PM
TTsteve's Avatar
Cool, thanks again
ECS Tuning
May 11, 2015 04:19 PM
vtraudt
Dec 6, 2013 12:49 PM
Semperfiboost1
Jun 18, 2013 09:39 AM
carbonOX
Oct 30, 2009 05:47 PM
thareals4
Sep 2, 2008 08:07 PM
