fuse 14 tripping everyday
Old Apr 4, 2012 | 10:57 AM
branstone's Avatar
Default fuse 14 tripping everyday
so yea, we had an issue where the overhead lights didn't work, windows wouldn't work and alarm wouldn't sound.
I searched the forum and found the fuse 14 fix. and yes it was blown. I replaced it and that fixes the issue, but now it seems to blow every 1-2 days...
anyone have any ideas?
Old Apr 9, 2012 | 12:47 AM
hunTTsvegas's Avatar
The reason for fuses blowing is because the Amp rating is being exceeded therefore causing the metal filament to disconnect or "blow". A lot can be told by tracing the signal (voltages) pathway from where it originates to where it's going. My last TT had a control module that managed to get some water/condensation due to a failing seal on the convertible top. Long story short, two electrical pathways shorted together causing a similar problem. Good place to start.
Old Apr 11, 2012 | 10:45 AM
branstone's Avatar
it turns out that the fuse is blowing because of the issue we are having with the convertible top pump motor. the part is $1060 !! hopefully its just leaking or the bleed screw is loose. they have to remove the top to get to it so either way a lot of $$.
jasonwkelly
Jul 18, 2015 10:07 AM
xav6ier
Feb 15, 2007 08:29 PM
AUD4CITY
Aug 25, 2006 08:25 PM
gregp1962
Jan 4, 2006 07:45 PM
