"FUSE" error/main fuse location?
Old Dec 2, 2009 | 06:21 PM
velvet jones's Avatar
Default "FUSE" error/main fuse location?
Hello All,
In an attempt to jump start my sister-in-law's TT, I did something to cause the "FUSE" error to come up on the center display. As expected, the car will no longer start. I checked all the fuses on the left side of the driver's dash, and all these fuses are still intact. Is there another place where additional fuses (or main fuse) are located?
Thank you in advance.
Best Regards,
Aaron
Old Jun 30, 2010 | 07:35 AM
surfnsmiles's Avatar
Default same issue
Hi Aaron. I'm running into the same issue with my TT. Jumped the car, drove around fine and now getting the "FUSE" error code and not starting. Did you find a solution for your issue? Thanks.
Lu
Old Jul 1, 2010 | 05:18 PM
quaTTrophobia's Avatar
Check the main fuses and fusible links in the holder/box above the battery?
Old Jul 2, 2010 | 01:51 PM
Thanks quaTTrophobia. Pulled all of the fuses and put them back in. Seemed to do the trick.
Old Jul 2, 2010 | 05:09 PM
Good.....that fuse panel is very suceptiblle to water, humiditiy, corrosion etc,
especially if you live in snow or rain country.
A brass tooth brush on the contacts and Krytox or dielectric grease every few years.
cristiancgarcia
Jun 8, 2017 11:54 PM
mr_hyde
Dec 1, 2010 12:21 PM
