G201 - ESP Light ON/ABS OFF - only in winter
Old Dec 28, 2009 | 03:00 AM
CcL's Avatar
CcL
Default G201 - ESP Light ON/ABS OFF - only in winter
So I got the dreadful ESP light on last winter (only when the weather warms up from say -20C to single digit negatives). All summer ESP worked flawlessly, got an alignment done. This winter, fell below -30C and worked its way back up to single digit negatives this week and same dreadul ESP light came on. It first came on when i accelerated hard out of a corner I think and stayed on regardless how many times I on/offed the car.
Cleared the ABS fault codes few times and finally the ESP lights went off (ABS light never came on before but they do flash when accessing the ABS module on vag-com). Drove out and it came back on in 5 minutes... grrr. Did a scan to see what was actually wrong and this came up:
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
57-00 - Electric Circuit Failure
Did some research and have NO idea what to do. Do I really try my luck with the brake switch before anything else? Can I just buy the G201 sensor or can I get it repaired/cleaned? Can it be the wheel speed sensors? Should I just attribute it to cold gremlins? MAF???
I believe ABS and Haldex still works but hell I could spin the wheels crazy now and I doubt ESP is doing anything to bring me back into a straight line. Any help would be much appreciated!
PS. when I had wheel spin in 1st accelerating hard and then shifted to 2nd on an icy road, the engine does bog, while the ESP light was on (rare occurance).
Old Dec 28, 2009 | 06:41 PM
jakej's Avatar
Its a resistance issue. Likely a sensor going out. I would try to locate the g201 sensor and relace that.
Old Dec 29, 2009 | 03:09 PM
CcL's Avatar
CcL
so where can I find a g201? how much are they? are used ones ok?
5ViPeRaY5
Oct 26, 2022 06:02 AM
vtraudt
Oct 24, 2013 09:28 AM
hartsoe1
Jun 24, 2013 10:07 AM
hartsoe1
Mar 16, 2013 12:16 AM
hartsoe1
Mar 13, 2013 11:02 PM
