gas guage q
Old Oct 13, 2005 | 07:53 PM
bongo's Avatar
Default gas guage q
Maybe Im just crazy...but my gas guage the last few fill-ups has shifted to the "F" about 1/4 tank...that is, when full the needle is way beyond the full mark and I get the low fuel warning (and low remaining miles display) while the guage itself reads about 1/4 tank...as if the whole thing shifted to the right LOL...is there a way to simply reset it (e.g. a fuse pull)
Thanks
Old Oct 13, 2005 | 09:00 PM
aTiTude's Avatar
Default RE: gas guage q
Sounds like maybe the unit has shifted behind your gauge cluster. Maybe try to pull the cluster out and see if you can reset it by just turning the unit back to the correct position.
Old Oct 14, 2005 | 07:52 PM
achTTung's Avatar
Careful screwing with the clusters, they are expensive, and theres really not much you can do with them.
Theres been problems in the past with clusters going bad, you may be seeing the first stages of that. When I had mine replaced, my fuel gauge was a bit off, maybe a 1/8th tank, and stopped, the speedo read -10. Also, temp gauge spiked to hot, as soon as the key was turned. I worked thru an independant garage, but ended up having to take it to audi for the new cluster to get the milage flashed in. If you have a VAG-COM cable, you can do that yourself, but its still tricky. Cost of a new cluster for my car was about $500, but if you have to buy it yourself, expect a few hundred more.
Old Oct 18, 2005 | 02:54 PM
RussTT's Avatar
First I would try resetting you ECU to do this unhook your battery for about 10 minutes then reconnect it.
Old Oct 18, 2005 | 10:22 PM
achTTung's Avatar
Make sure you have your radio security code before you do that though, assuming you have the stock unit. Disconnecting the battery will lock the radio, and its kinda expensive if Audi has to look it up.
Old Oct 19, 2005 | 06:03 AM
bongo's Avatar
thanks...i'll try this..have the security code, dont want to touch the guage itself...luckily if the cluster is going have an ext. warr
Old Oct 21, 2005 | 01:54 AM
VelociTT's Avatar
mine does this as well!! took it to my audi dealer and they are going to replace the entire gauge cluster for me has your backlighting gotten weaker by any chance??
Steel2040
May 5, 2010 09:29 PM
Kyle75
Jul 11, 2007 12:02 PM
Kyle75
Jun 22, 2007 06:54 PM
TTsteve
Apr 13, 2007 08:18 PM
darkblueS4
Feb 13, 2005 08:48 PM
