Gauges too bright
Old Jan 5, 2012 | 11:20 AM
kwaskow's Avatar
Default Gauges too bright
I added a couple of gauges from Prosports, and they are great, but not dim-able. So, at night they are a bit too bright. Wondering if anyone has ideas for a tinted lens cover, or other thoughts? Prefer not to break into the wiring to add a dimmer circuit.
Old Jan 5, 2012 | 01:58 PM
cincyTT's Avatar
I'm make believe
You could add them to the wiring for the cluster and when you dim the cluster, you dim the gauges.
Old Jan 6, 2012 | 09:16 AM
kwaskow's Avatar
I was wondering if there might be any peel and stick lens covers with different shades of tinting
Old Jan 6, 2012 | 09:21 AM
cincyTT's Avatar
I'm make believe
You can buy window tinting at most parts stores or even walmart. It's peal and stick. You can also order some laminx online.
Old Jan 6, 2012 | 12:53 PM
TTQ2K2's Avatar
Cincy,
where do you tap-in? is there a diy available?
cheers.
Old Jan 6, 2012 | 02:30 PM
kwaskow's Avatar
I'll try the Lamnix, thanks!!
Old Jan 6, 2012 | 04:11 PM
cincyTT's Avatar
I'm make believe
Originally Posted by TTQ2K2
Cincy,
cheers.
There should be info floating around. But you just tap into the dimmer wiring
A4Ash
Apr 21, 2010 10:09 AM
ferrarf1_07
Jan 23, 2008 12:54 AM
mikejaeggi
May 29, 2007 01:15 PM
illridezwannabe
Jun 16, 2006 07:15 AM
viper771
Dec 20, 2005 02:01 PM
