GFB Hybrid BOV
Old Apr 28, 2007 | 08:38 PM
sheepcan's Avatar
Default GFB Hybrid BOV
Finally got it today, after it was a week late, but got it put on and it works great. The sound is a lot louder than my forge 007. It was real easy to adjust too, you just turn the vaccum nipple.
Oh and eliTTe did you ever get yours sounding right.
Old Apr 28, 2007 | 09:19 PM
eliTTe's Avatar
Default RE: GFB Hybrid BOV
Glad you like it, sounds to be a good product, I should have gone that route.
I have still not gotten my forge splitter right, still flutters like crazy when I shift... oh well, I did get my custom relocation kit finished and on the car last night, it seems to sound cleaner so thats good.
I'll be making a post shortly about the relo kit.
Old Apr 28, 2007 | 09:24 PM
cincyTT's Avatar
I'm make believe
i wounder if your spring could be upside down. would switch it and give it a go. worth a shot at this point.
But back on topic, you think the gfb is worth the extra $$$?
Old Apr 29, 2007 | 05:49 PM
sheepcan's Avatar
Don't know if it's better then the hybridforge, never used or heard one, but it is definetly a lot louder then the forge 007 i had.
And I was thinkin the same thing about his spring being upside down. So you might want to try just to see what happens.
Old Apr 29, 2007 | 05:52 PM
sheepcan's Avatar
Oh another thing now that I put the gfb on, my boost spikes at like 15 but it goes back down to about 12. Don't know if its supposed or if its a good thing. I may not have it adjusted quit right, don't know. What do you think?
Old Apr 29, 2007 | 06:52 PM
cincyTT's Avatar
I'm make believe
IF your not releasing pressure early or have massive flutter, your good.
Old Apr 29, 2007 | 06:54 PM
sheepcan's Avatar
I have a little flutter whenever i only hit about 5 psi but on the website they say that that is normal.
How wouldi know if i'm releasing pressure early?
Old Apr 29, 2007 | 07:02 PM
cincyTT's Avatar
I'm make believe
low psi flutter is normal. If you have an intake you will hear it or see it on a boost guage. Its you still giving gas and your valve opens. Meaning it needs more pressure. If you are still stock airbox, remove it and drive around the block a couple times.
Old Apr 29, 2007 | 07:07 PM
sheepcan's Avatar
I don't have a stock airbox so I guess everything is normal.
Old Apr 29, 2007 | 07:22 PM
cincyTT's Avatar
I'm make believe
i would assume so
