Good News.
Old Sep 24, 2008 | 05:44 PM
myxyzxo's Avatar
SoCal Crew Member
Default Good News.
Well as I mentioned in another post. On Saturday night as I was driving, my car suddenly lost all power. I turned off the engine and tried to re-start it but it wouldn't turn.We guessed it was a broken Timing Belt. Well we took the car apart to find out that the belt was not broken. But had stripped and lost 16 of the teeths. We did a TB job, removed the valve covers to look for more dmg. Oddly enough, nothing was wrong with the valves (whew, saved me an assload of money there). Right now putting the car back together should be finished in about 30 minutes.
Old Sep 24, 2008 | 05:48 PM
ChrisLUpo's Avatar
Good luck hope all turns out well
Old Sep 24, 2008 | 05:58 PM
Murderface's Avatar
If it failed while driving and then you cranked it again after that, chances are you did bust something.
This is just as bad as it breaking.
If all you pulled was the valve cover, there's no way you can tell what shape the valves are in. All you can see are the lifters/springs. The valves sit much lower. You'd have to pull the whole head to see if the valves/pistons are damaged. Also sure hope you replaced the water pump while you were at it, since that could have caused it.
Old Sep 24, 2008 | 06:51 PM
.clipse's Avatar
SoCal Crew Member
^ and/or tensioner.
but hopefully all is well!!
Old Sep 24, 2008 | 11:28 PM
myxyzxo's Avatar
SoCal Crew Member
Sigh... Engine does not start gonna pull the head. There are some bent valves. So gonna need at least another day b4 car is up and running. other than that everything else is changed.
Old Sep 24, 2008 | 11:34 PM
theTTkid's Avatar
bummer dude, that sucks a big one
Old Sep 25, 2008 | 12:05 AM
myxyzxo's Avatar
SoCal Crew Member
haha not really.. Good news is I am drunk.. hahahaahahahahahhaha
Old Sep 25, 2008 | 12:07 AM
Murderface's Avatar
don't go banging without protection, much like your pistons+valves just did.
Old Sep 25, 2008 | 12:09 AM
myxyzxo's Avatar
SoCal Crew Member
hahahaha.. 2morrrow gonna have the head rebuilt, change out the valves etc..
Old Sep 25, 2008 | 12:25 AM
theTTkid's Avatar
you got parts pretty quick...
