Good ol' P1136
Old Nov 2, 2008 | 06:23 PM
Tmoney's Avatar
Default Good ol' P1136
Hey guys, i was just wondering, if i were to replace my Front O2 sensor, would that be a hassle?? ive actually never gone on a search for it, but i have a feeling that i have a faulty one.
Now if its a vaccum leak, which i know are sneaky lil things to find, where would be the best place to look first for the possible leak??
Old Nov 2, 2008 | 06:42 PM
Wintermute's Avatar
I did it when I put my d/p in. It's in a real easy location.
Old Nov 2, 2008 | 07:12 PM
ninjatturtle's Avatar
Member
I found my leak under the intake manifold at a check valve. Look at all hoses and tubes coming out of the intake manifold. If any of those are split the engine will suck extra air though those at idle.
Old Nov 2, 2008 | 07:53 PM
Mobius97's Avatar
The 1st sensor is very easy to change. Get yourself an o2 wrench and have at it. I removed the strut bar when I was in there. Don't recall if it makes it easier or not for just the o2 sensor. I was removing the sensor out of my way to get at my downpipe hardware.
Old Nov 2, 2008 | 10:46 PM
drsmith's Avatar
Is the first O2 sensor in the same location on the 225q and 180q? i want to change mine too but was just wondering if its going to be a bitch to get out due to being seized in! anyone had any experience?
Also wheres the best place to buy, i hear a lot about 'universal' items over OEM, are they good enough? all advice appreciate!
Old Nov 2, 2008 | 11:05 PM
Mobius97's Avatar
Mine came right out with an o2 wrench. Not sure about the 180 but it is should be in the same relative area shortly after the hotside of the turbo.
Old Nov 3, 2008 | 12:46 AM
drsmith's Avatar
can it be done from the top or does it have to be accessed from beneath? wheres the best place to get the wrench from?
Old Nov 3, 2008 | 01:40 PM
Mobius97's Avatar
I picked it up for 5-7 bucks from the local auto parts store. It is just a tall socket with a slit down the side to pass the wire through. It just uses any standard socket wrench. You can reach it from the side of the car on top. With removing the strut brace and the o2 it should literally take you ~10mins.
Old Nov 3, 2008 | 08:17 PM
drsmith's Avatar
good stuff!.... do you need to remove the turbo pipes or other fiddly bits? or can it simply be done by taking off the strut brace and then lubing up the o2 sensor?
what sensor to replace it with? anyone got part numbers for the universal ones?
Old Nov 4, 2008 | 04:43 PM
Mobius97's Avatar
http://www.ecstuning.com/stage/edpd/...egory=Emission
There you go. You may be able to find the o2 sensors someplace cheaper tho (I have never had to buy them before).
The Shly Lamda wrench that is listed at 40 from ECS. I bought some other off brand for quite less. Here is a link to one of those as well.
http://www.partsamerica.com/ProductD...egoryCode=3412
