Grill install
Old Jun 18, 2008 | 06:03 PM
keefboz's Avatar
Default Grill install
Anybody installed a grill themselves? I had a search and couldn't find a DIY on it.
Any advice would be great, thank you.
Old Jun 18, 2008 | 06:22 PM
cmh's Avatar
cmh
Default RE: Grill install
step 1. remove bumper
step 2. release tabs on grille from the back side and remove old grille
step 3. install new grille
step 4. re-install bumper
There are those that say you can remove the old grille without pulling the bumper, but I don't think it would be in reusable condition if you did it that way b/c all the tabs would be broken.
Old Jun 18, 2008 | 06:24 PM
cmh's Avatar
cmh
If you need a DIY for removing the front bumper search for one about clear corners/headlight reflector removal, there are lots.
Old Jun 18, 2008 | 06:29 PM
myslow1's Avatar
from what i have read you dont "have" to remove your front bumper...
Old Jun 18, 2008 | 06:30 PM
cincyTT's Avatar
I'm make believe
no, but if you want more room you can. However removing it for the first time is a pita
Old Jun 18, 2008 | 09:30 PM
Mobius97's Avatar
It can easily be done without removing the bumper. I just tugged hard on the stock grill to remove it. I did however break quite a few of the tabs on the grill itself doing so.
Old Jun 18, 2008 | 10:25 PM
achTTung's Avatar
which kinda kills the dollar value if you ever wanna sell it... or reinstall it to sell the car....
Like EVERYTHING else with these cars, it takes a little time to pull the bumper, but it's not hard.
Old Jun 18, 2008 | 10:30 PM
Wintermute's Avatar
Do it proper & take off the bumper. Don't try to rip it out. You'll destroy your bumper.
Old Jun 19, 2008 | 12:38 AM
Mobius97's Avatar
No you won't. I was able to take it out but like I said I did break some of the tabs on the grill. The stock one can still go back on without any trouble just minus a few tabs. There are a ton on there. The bumper isn't that hard to remove as stated though. I have removed mine a few times. The hardest was the first time when I installed my fmic.
Old Jun 19, 2008 | 12:40 PM
keefboz's Avatar
Looks like the general opinion is to remove the bumper. I will search for how to do this, time is not an issue, just want to get the new grill installed the safest way.
Thanks for the advice
