Grinding Gears... =o
Old Jul 19, 2007 | 07:38 PM
krnaudi's Avatar
Default Grinding Gears... =o
Well, I was driving semi-aggresivly today and noticed a loud clunk/grind noise when i downshifted to 3rd. Then I let off and came to a stop light, and from 1st, while engaging the clutch i hear the clunk/grinding again., and seems like my gears are slipping or not engaging 100%
Any ideas what it could be?
Old Jul 19, 2007 | 08:52 PM
ouTTie914's Avatar
Default RE: Grinding Gears... =o
Syncros or your clutch.
Once in a blue moon I'll get a clunk, but never a grind.
When was the last time you changed your tranny fluid?
Old Jul 19, 2007 | 08:56 PM
eliTTe's Avatar
if 3rd is grinding, change your tranny fluid to a beter one... its a common problem
Old Jul 19, 2007 | 09:51 PM
krnaudi's Avatar
sweet, thanks! I'm not sure when the last time i changed my tranny fluid is, I just hit 66,000 today. What kind brand do you guys recommend?
Oh, I noticed that at 60mph my rpm range is around 3k-3.2k and I was wondering if this was normal, just seems a weebit higher than normal.
Old Jul 19, 2007 | 09:57 PM
eliTTe's Avatar
Most use redline MT-90, avaliable at ecs tuning... but I like to be different and use the Motul gear fluid, avaliable at pure motorsport... no more grinding here.
dont know about the rpms... you have a 5spd so your ratios are different than mine.
Old Jul 19, 2007 | 10:06 PM
ouTTie914's Avatar
In 5th going 60 MPH, 3k rpms sounds about right.
Old Jul 20, 2007 | 01:06 AM
theTTkid's Avatar
just a side note... you hit 66k miles so get your timing belt done if you havent done so already
Old Jul 20, 2007 | 01:49 AM
Murderface's Avatar
That's about right. At highway speeds the needles are ALMOST in the same positions.
Old Jul 20, 2007 | 06:28 AM
timbo108's Avatar
I changed mine out with Royal Purple full syn a couple months ago. Synchros are much smoother and the overall shift action is much better. Was a pretty easy job.
Old Jul 20, 2007 | 07:06 AM
225tt's Avatar
Did MT-90 in mine, now my 1-2 upshift is smooth as a baby's butt. Well almost....
