Group Buy Water/meth
Old Apr 25, 2008 | 09:54 AM
  #241
JettaRedII's Avatar
Default RE: Group Buy Water/meth
Yep. That's right. I got a posting from Dvldoc who said most people set the full (max) setting to be about 3/4 of their peak boost.
Old Apr 25, 2008 | 10:00 AM
  #242
MeanAudiA6's Avatar
[blockquote]
good deal now i jsut gotta tune...lol the fun begins...since im using lemmiwinks cuz unisettings doesnt work for some reason...what did your timing look like with that giac chip before u started tuning? [/blockquote]
Old Apr 25, 2008 | 10:09 AM
  #243
JettaRedII's Avatar
Don't know. Never measured it.
Old Apr 25, 2008 | 10:24 AM
  #244
MeanAudiA6's Avatar
http://www.alcohol-injection.com/for...fuel-1254.html
THIS IS VERY INTERESTING....i might try putting in the 87oct fuel and see what happens...i did noticed with out touching my boost controller that the boost raised about 3 psi....i had it maxed at 19-20 now its 22-23 psi....
Old Apr 25, 2008 | 10:28 AM
  #245
JettaRedII's Avatar
Yeah, but don't mess with your timing yet if you are going to run 87 octane.
  #246
MeanAudiA6's Avatar
and jetta what i meant was how did the program display your timing> before TDC? or what did u change...u used unisetting didnt you? i know lemmiwinks will work tho...i havnt booted lemmiwinks in a while and im at wrk just trying to get a head start for when i get home after class....
Old Apr 25, 2008 | 10:43 AM
  #247
JettaRedII's Avatar
Oh, using lemmiwinks or Unisetting, find the timing setting (Channel 9) and increase it to three degrees. Each increment is .75 degrees, so the end value for 3 degrees is Channel 09: 0x04 (from 0x00).
Old Apr 25, 2008 | 10:52 AM
  #248
MeanAudiA6's Avatar
gotcha thats all i needed...thanks again...is that what u have yours on?> or did u go 0x05 and u started by going 0x01 0x02 etc etc till u got where u are now the 0x04? since u cant get an even 4 its either 3degrees or 3.75 degrees or 4,5 degrees=0x06??? this was the method i was gonna use and then use vag com to see when the timing was being pulled and use the butt dyno to feel when its pretty strong...but i do know i dont wanna go pst 4-5 degrees lol
Old Apr 25, 2008 | 11:01 AM
  #249
JettaRedII's Avatar
I started at 0x01, 0x02...and stopped at 0x04. I have not gone higher than that. If I do, I may want to lower my boost a bit. It would be interesting to see if power increases. Sometimes my car feels faster with 12 psi than it does at 20 psi.
Old Apr 25, 2008 | 11:04 AM
  #250
MeanAudiA6's Avatar
i feel ya on that...it does feel like the powerband got longer but u feel it sooner now..
