Has anyone put the Forge FMIC kit for the 180TT on their car??
Old Jul 29, 2007 | 05:17 PM
cincyTT's Avatar
I'm make believe
Default RE: Has anyone put the Forge FMIC kit for the 180TT on their car??
just hook up that line to the back of the manifold and run it over to the stock line and then it should be obvious on where to hook it up. Its either going to be before or after that check valve you showed on the stock line.
Old Jul 29, 2007 | 06:13 PM
zero388's Avatar
how do you undo the check valve?? does it twist off pull apart or what?
Old Jul 29, 2007 | 06:28 PM
cincyTT's Avatar
I'm make believe
should have some clamps to unscrew to get it off. There should be a check valve in the line still.
Old Jul 29, 2007 | 06:51 PM
zero388's Avatar
I am still trying to put in the 225 brake booster line. The problem is I dont know where to put it in. Here are two pictures of things that I think are the check valve so I am not sure where to take the line apart.
The thing circled in red is what I think might be the check valve. Also it is where the end of the hose circled in red in the second picture was attached.
The thing circled in red by the neuspeed sign is what I think could also be the check valve. and if it is I dont know how to get it apart.
These are the things I am stuck on so any help is greatly appreciated.
Old Jul 29, 2007 | 06:59 PM
cincyTT's Avatar
I'm make believe
the second pic shows the check valve circled.
can you get a better pic of the end on the top right?
Old Jul 29, 2007 | 07:11 PM
zero388's Avatar
Here is a better picture( this is the end of the 225 brake booster line included in the kit)
Old Jul 29, 2007 | 07:15 PM
cincyTT's Avatar
I'm make believe
will that fitting reach this nipple?
Old Jul 29, 2007 | 07:22 PM
  #18
zero388's Avatar
It can but it wont fit in. That nipple is where the thing circled in red over the battery connects.
Old Jul 29, 2007 | 07:46 PM
  #19
cincyTT's Avatar
I'm make believe
take the hose sitting on the battery (4" long) and clamp it it to the nipple above and end of the booster line.
Old Jul 29, 2007 | 10:02 PM
  #20
cincyTT's Avatar
I'm make believe
hope its working, still not back asking ?'s
jhsoccerodp
Jan 6, 2009 04:16 PM
taifighter
Mar 17, 2008 11:17 AM
precision tt
Jan 25, 2008 12:31 AM
AudiOso
Aug 23, 2007 02:34 PM
DurTTy
Aug 7, 2007 12:20 PM
