Have your a/c checked!
Old May 10, 2008 | 06:13 PM
fireman9585's Avatar
Default Have your a/c checked!
My mechanic told me my compressorhad gone bad, probably becausethe freon had gotten low and the low pressure switch (if it has one) didn't shut it down, thereby allowing the compressor to wear itself out. If you've had your tt for more than 2 or 3 years, have someone look it over.
Old May 10, 2008 | 06:15 PM
cincyTT's Avatar
I'm make believe
Default RE: Have your a/c checked!
The pressure in my system was fine and my compressor took a dump (8yrs old and 100k miles). Just got a slightly used one installed.
Old May 10, 2008 | 07:01 PM
achTTung's Avatar
yeah, its not just refrigerent in there, the AC system has lubricant circulating as well. Low on one means low on the other, which is why compressors go bad.
Old May 10, 2008 | 07:26 PM
cincyTT's Avatar
I'm make believe
my system was basically fully charged. And i know there is conditioners and lubercants in there
Old May 10, 2008 | 09:13 PM
achTTung's Avatar
you do, not everyone else does. More of a tip for future reference for the few that actually DO use the search.
Old May 10, 2008 | 09:35 PM
Where can I find a good used compressor?
Old May 10, 2008 | 09:40 PM
exTTreme's Avatar
http://forums.vwvortex.com/zerothread?id=3674109
theres one for sale can also do a serch on that site had 60ish results just now
Old May 11, 2008 | 04:30 PM
jakej's Avatar
if you do not use your ac reguarly (ie: only use it 6 months during summer), the oil does not circulate in the compressor where the belt spins it. If you don't want your compressor to break run your ac for 30 secconds every week or so. Defrost runs the compressor in winter.
Old May 13, 2009 | 04:41 PM
kwaskow's Avatar
how much should an AC pressure switch cost at a mechanic, not dealer?
Old May 14, 2009 | 08:46 PM
achTTung's Avatar
