headlight lenses
Old Jan 14, 2011 | 09:21 AM
fireman9585's Avatar
Default headlight lenses
The headlight lenses on my 2001 225 tt coupe are so yellow I have to keep my brights on at night most of the time just so I can see a reasonable distance. I've tried some of the products for clearing them, but when I compare them to the lenses on a new car, I realize just how bad they really are. Anyone have a handle on how much it would cost to replace them?
Old Jan 14, 2011 | 10:41 AM
TTQ2K2's Avatar
New plastic is not available. Full light assemblies (used) are usually in the 200-400 dollar range.
Have you tried the 3m lens repair or renewal kits? I used the 3m renewal kit ((#39014) on one lens, with deep scratches, and it did a very good job of getting it out. Not completely out, but reduced by 80-90% or so.
Before: Big F'n scratches.
After: Small f'n scratches.
cheers.
Old Jan 14, 2011 | 02:38 PM
myxyzxo's Avatar
SoCal Crew Member
Try sanding then buffing them with a buffer. If that doesn't work I have a set of headlights that I can sell yah. they have no cracks, leaks & are in perfect working condition.
Old Jan 14, 2011 | 03:58 PM
Thanks, guys. I'll keep working on them.
Old Jan 14, 2011 | 05:25 PM
AutomediaJoe's Avatar
I found a video of a bunch home remedies and stuff that you might want to try before shelling out hundreds of dollars.
http://www.youtube.com/watch?v=Cy_WF5Iei_I
Old Jan 16, 2011 | 01:37 PM
warranty225cpe's Avatar
should only cost you about 100-150 for a PROFESSIONAL headlight restoration. I had both of mine done and they look awesome. see ifthere is a headlight DR. in your phone book. the problem with the DIY kits, is that they dont have a liquid clear to coat the surface with. you can sand and polish them forever, but unless you have a clear liquid to spray on them your results are going to be limited.
steve53mg
B7 Models
Aug 26, 2012 07:36 PM
taifighter
Apr 16, 2011 12:46 PM
fireman9585
Oct 30, 2009 02:04 PM
tmanning
Jan 7, 2008 02:42 PM
kakarot
May 30, 2007 10:44 AM
