Help asap!!!
Old Apr 7, 2013 | 02:57 PM
Mez1986's Avatar
Default Help asap!!!
Right hi guys im new to this site and in desperate need for some advise...
I am currently contemplating buying an Audi TT 1.8t Quattro (225) and need some help. I have literally THRAWLED and taken apart EBAY and Autotrader for the right car but need some advice, the car I have in mind is advertised for £3300 with 95k on the clock, currently has a clear HPI check .... full services history and at the last service (89k) the following was performed.....
Labour Description
20k service and inspection - £ 68.00
Brake fluid flush - £ 68.00
Fit Downpipe and Lambda’s - £ 68.00
Health Check - £ 55.00
Fit rear disc’s and pad’s - £ 68.00
Stage 2 Remap - £400.00
Fit Cambelt Kit - £ 68.00
Replace cam cover and tensioner gasket - £ 68.00
Parts Description
Cambelt kit (inc water pump and thermostat) - £340.00
Lambda 1 - £112.00
Lambda 2 - £ 96.00
Maf - £ 85.25
Diverter Valve - £ 28.45
Boost hose – £ 21.16
Pollen filter - £ 14.50
Air filter - £ 12.75
Oil filter - £ 5.46
Audi platinum oil x 5 – £ 27.50
Oil disposal - £ 2.50
Spark plugs x 4 - £ 46.76
3” downpipe and sports cat - £ 4.50
Rear discs x 2 - £ 56,00
Rear Pads - £ 35.00
Dipstick tube - £ 5.65
Dot 4 Brake fluid x 2 - £ 17.80
Cam cover gasket - £ 35.86
Tensioner Gasket - £ 5.36
Boost Hoses - £ 28.16
Sub Total - £1427.46 + Vat
Now the car is the 2000(W) reg model which means 13 years old and the seller reassures me that the only reason they are selling is because of a different car purchase ....
now I cant simply go and view this as I live in Swansea and the car in question is on the outskirts of London ...it cosmetically looks extremely well looked after and in the listing it states that it still looks drives and handles like new and that the car was previously owned by the wife of MFC Tuning
what do you think I should do???
is 95k considered high millage taking into consideration all of the above 'assumptions' are correct?
should I walk away? or do you think its worth taking a chance on ?
Old Apr 7, 2013 | 09:54 PM
Toddster385's Avatar
I just bought the same car but without all of the service records and because it is a 2001 has a bit of rust, I have said it is a big gamble but I am glad I did, I love it
Old Apr 8, 2013 | 08:15 PM
stuck amals's Avatar
I would think you could find a local independent repair shop that you could hire to inspect the car for you?
In the USA we can use the Better Business Bureau (BBB) and the American Automobile Association (AAA) to find reputable repair shops. As*well as forums such as this on the web. There should be some TT enthusiasts in the London area that would be pleased to help out.
Best of luck.
Mmspartan
Jun 14, 2011 05:14 PM
zerodegre
Sep 20, 2009 11:33 PM
dejahn23
Sep 22, 2008 07:28 PM
bhunt17
Feb 21, 2008 07:07 AM
silveraudib6
Feb 8, 2008 04:11 PM
