help, my kmac bushings :(
Old Feb 12, 2008 | 03:19 PM
hotgrass's Avatar
Default help, my kmac bushings :(
i installed my kmac bushing last saturday and when i looked today, the one on the left rear (lower arm), the red bushings corners were gone, i think it was cracking, maybe i didnt tightend it much. am i gonna be fine or do i need to purchase that red bushing? where can i purchase it? anybody else had this problem? im kind a stressing out cause i dont want to spend anymore money, im poor right now
Old Feb 12, 2008 | 05:08 PM
achTTung's Avatar
Default RE: help, my kmac bushings :(
ouch. I think I did less damage to that, and I tried to grind a guardrail with my car.
I'm gonna guess you'll need new bushings, or your control arms are gonna shift around. Do a good inspection, everything should have been TIGHT.
Call up the guys at TTstuff, they should be able to sell you just the bushings. Its $16 a pair direct from KMAC, but then you need to pay some international tariffs or some **** since its coming from Australia
Old Feb 13, 2008 | 08:24 PM
hotgrass's Avatar
i called them and they said it'll cost me f@#$ing $70!!! does anybody have an extra one?
Old Feb 13, 2008 | 09:34 PM
ouTTie914's Avatar
ORIGINAL: achTTung
I have a feeling even with customs you'll spend less than $70.
Did you grease it up enough upon installation?
Old Feb 13, 2008 | 09:47 PM
hotgrass's Avatar
yes, i greased it up, i actually called kmac in australia and they said that they will talk to shox.com to send me two new bushings!
Old Feb 15, 2008 | 01:56 PM
hotgrass's Avatar
i still need help, still no bushing,does anybody have a solution for this? should i put a washer one the side instead?
Old Feb 15, 2008 | 06:22 PM
ouTTie914's Avatar
Honestly, I wouldn't drive the car until you get a new bushing on there...
1.) If that bolt snaps you'll be in a serious accident!
2.) You could damage the bolt, and have to buy a new one.
3.) Did I mention what would happen if the bolt snaps?
Old Feb 15, 2008 | 06:29 PM
AudiOso's Avatar
I haven't had any trouble with my setup. Did you install this yourself?
Old Feb 15, 2008 | 07:18 PM
hotgrass's Avatar
yes, i did instal it myself. they finally called me today and they will send me 2 bushings. hopefully
Old Feb 15, 2008 | 08:47 PM
achTTung's Avatar
That price I quoted you was quoted me DIRECTLY from KMAC. If you're getting quoted $70 it isn't for the poly sleeve, its for the whole bushing. If you still don't have resolution for this issue in a couple days, PM me. I'll give you a hand getting something straight.
