HELP - TT front end noise
Old Mar 11, 2008 | 11:02 PM
Hitchr10's Avatar
Default HELP - TT front end noise
I have recently started to hear a scary noise coming from my front end. The noise is something between a knock and grind and I believe it might be related to my clutch or trans. The car only makes the noise when the car is IN GEAR (doesn't matter which gear) and either decelerating or when I'm not on the pedal AT ALL. The noise will go away when I give the car any gas. The sound becomes quicker with the speed of the car, but is not related to the RPMs of the engine. Also, the sound is not affected by whether or not I'm turning or using the brakes. Does anyone have any idea of what this could be?
Another interesting tidbit: the sound used to ONLY start after I had driven the car at a high speed (70+). The sound is the loudest when I'm in gear, not giving the car any gas, and rolling along at about 30.
Any suggestions before I take this in with a blank stare and open wallet?
Thanks!
Old Mar 12, 2008 | 05:36 PM
Hitchr10's Avatar
Default RE: HELP - TT front end noise
Any ideas? At all?
Old Mar 12, 2008 | 05:46 PM
cincyTT's Avatar
I'm make believe
You could have worn out mounts. When i did my dogbone mount (connects bottom of trans to frame), the mounts were falling apart. If its part of the clutch/tranny, change the fluid to Redline MT-90 fluid.
Old Mar 12, 2008 | 06:53 PM
jakej's Avatar
cv joints?
Old Mar 12, 2008 | 09:00 PM
DEDMN_TT's Avatar
I had a knocking/rattling sound before from the engine bay. would you be able to isolate from where abouts in the engine were you hearing the sound? It might help the guys figure out what parts are around the noise. Mine came from the passenger side of the engine and turned out to be a failed timing belt tensioner. the noise only happened between 1300 - 2000 rpm.
g'luck
Old Mar 12, 2008 | 11:09 PM
Hitchr10's Avatar
My noise is coming from the drivers side. Im not sure if it's related, but I also have a minor knock when I hit bumps coming from that area. That knock is loudest when the car is cold, but goes away for the most part after I've driven a few miles. The knock I'm concerned about (subject of this post) only occurs when I am in gear and NOT giving the car any gas; as soon as I give it gas or take it out of gear, the noise goes away. Would this happen if my CV joint was bad?
Old Mar 13, 2008 | 12:58 AM
themysteryman83's Avatar
ORIGINAL: Hitchr10
This is most likely the ever annoying front sway bar. Mine does the same thing. When I redid the bushings on mine, no one told me i'm supposed to cut off the plastic part on the sway bar that the bushings attach to.
Old Mar 13, 2008 | 01:00 AM
ORIGINAL: Hitchr10
Thanks!
I agree with Cincy, it could be the mounts.
Old Mar 13, 2008 | 07:00 PM
Hitchr10's Avatar
Well, it's in the shop....we'll see what it is tomorrow (hopefully)....
Stay tuned....
Old Mar 14, 2008 | 05:38 PM
Hitchr10's Avatar
They don't have any clue....CRAP
