HID Ballast Problem
Old Feb 1, 2009 | 05:15 PM
jhsoccerodp's Avatar
Default HID Ballast Problem
I have confirmed my problem with my HID is my ballast, and its cheaper to upgrade to aftermarket 55W hids, which would be much brighter, does anyone know which two wires on the headlights are the positive and negative for the actual HID, and if ill get a bulb out warning?
Old Feb 2, 2009 | 05:38 AM
vegastt's Avatar
I have a spare Ballast that I got but was for a different model headlight.
I believe it was from an 2002, it's the type that sits on the side of the headlight.
If you want to take it off of my hands I'll sell it dirt cheap.
Just shoot me a PM.
Old Feb 2, 2009 | 01:39 PM
Im going to be doing aftermarket kit, do you guys want a write up?
Old Feb 2, 2009 | 09:00 PM
joshuo's Avatar
Yes please!
My headlight is about to die and I'm pretty sure it's the ballast
(ignites every time, mostly just doesn't stay lit or dies within 30 secs.)
A write-up would be superb!
Old Feb 2, 2009 | 09:15 PM
Here is my current thoughts, completely remove headlights and remove old ballast and ignitor to make more room, and then going into the Ballast there is a yellow and a brown, and a green black and red going out, and the yellow and brown should be our + and -. Im just going to remove that harness and splice into the yellow and brown. That will give me my power source, and then mount the ballast in oem location with double sided tape, and since the ballast is built in ignitor, just run the d2s connector to the bulb. And seal up any holes so moisture doesn't get in.
Old Feb 2, 2009 | 10:11 PM
joshuo's Avatar
Sounds brilliant. How much do you think the whole thing would run?
Are you planning on using the same hue lamps?
Old Feb 2, 2009 | 10:17 PM
less than 100 bucks, and that includes new bulbs and upgraded brighter 55w ballast. Im pretty excited. After i get it working flawless ill post the diy and where i ordered mine. I have 8k bulbs already and i am getting 6k with the kit. Ill have to confirm my 8k are rated for 55w before i use them.
Old Feb 4, 2009 | 01:46 PM
IT WORKS, no bulb out warning. Ill type up a diy later tonight, or while im in engineering class.
Old Feb 4, 2009 | 02:23 PM
joshuo's Avatar
Sweet!
Can you post up a link with the parts you used?
I'm telling you, this thread came just in time, my light doesn't work anymore now.
So you replaced pretty much everything concerning the HID's right? (ballast/igniter/bulb)
Old Feb 4, 2009 | 02:30 PM
yes, everything was replaced, since if one ballast goes out now, the other is bound to go out soon, and i can do the whole thing for less then one ballast cost used for new stuff. I got the 50w/55w kit from xhidoutlet on ebay. Link: http://cgi.ebay.com/ebaymotors/ws/eB...ht_7691wt_1030
but you need the d2s amp connector, id call them, they will hook you up with a good deal and they are awesome people, the number is on the page. If you call them today they would send it out today, i was impressed i got it the next day. 8000k look great
