High-Flow Cat & Resonator
Old Jul 20, 2007 | 12:37 PM
cincyTT's Avatar
I'm make believe
Default RE: High-Flow Cat & Resonator
b/c it came from a N/A guy. You shouldnt loose any low endby getting rid of restricions at the same diam piping.
You would loose a little lowend with a larger exhaust but the spool and power more than makes up for that.
Old Jul 20, 2007 | 01:41 PM
gravitt's Avatar
Curious, what kind of BT setup were you looking forward to? Common "bolt-on" BT setups such as APR and Del Rio require that you use their proprietary intake manifolds, exhaust manifolds, downpipes, FMICs, software, etc. If you went that route (which might cost more a little moremoney, but less headache in the long run), you'd have to part out your FMIC and downpipe anyways- so no, these mods you're doing aren't "supporting" a future BT project.
Old Jul 20, 2007 | 01:44 PM
cincyTT's Avatar
I'm make believe
APR's kit is the only one that comes with a fmic. Others can use what he has. But yes, the dp will have to go unless an....lol....eliminator...lol.... is used.
Old Jul 20, 2007 | 11:55 PM
neur0tic's Avatar
Are you kidding? The downpipe shouldnt have to go should it? I mean... I guess the mount flange is turbo specific but the guy making the downpipe shouldn't have a problem with that right? I would imagine he could work with that
Old Jul 21, 2007 | 12:08 AM
cincyTT's Avatar
I'm make believe
differnt manifolds put tubos in differnt places and directions. An atp dp wont fit a apr manifold with both using a t25 housing. They are mounted in differnt location and are flipped 90* differntly
Old Jul 21, 2007 | 12:21 AM
neur0tic's Avatar
Hmm. I see. So I'll look forward to changing at least the top part of my dp again with the turbo, from the flex tubing up. Damnit.
Old Jul 21, 2007 | 12:24 AM
cincyTT's Avatar
I'm make believe
that may work. I would either not get the dp or just sell it and get a new one. By the time yougo BT, there will hopefully be more options (kits and tunning) for the 225's
Old Jul 21, 2007 | 12:15 PM
  #18
neur0tic's Avatar
So does anyone know of a compatible 3" cat and resonator? I was on summit racing and saw a ton of them and just didn't know which would fit the the car. lol
Old Jul 21, 2007 | 12:17 PM
  #19
cincyTT's Avatar
I'm make believe
Just about any cat should fit along with a skinnier resinator
Old Jul 21, 2007 | 12:20 PM
  #20
neur0tic's Avatar
sounds good. Why are the cats @ thettshop.com like $800? Cats on summit racing are like $200 max. Most are more like $100
