High RPMS
Old Aug 27, 2007 | 08:55 PM
pat7755's Avatar
Default High RPMS
Sup yall. I have a stock 2000 audi tt 1.8l. I just recently noticed that my RPMS seem to be a little higher than normal considering the speed and gear. any ideas of what could be causing this?
Old Aug 27, 2007 | 08:56 PM
cincyTT's Avatar
I'm make believe
Default RE: High RPMS
you just change wheels?
Old Aug 27, 2007 | 08:58 PM
diehlryan's Avatar
clutch going bad?
Old Aug 27, 2007 | 09:05 PM
ouTTie914's Avatar
Usually when the clutch is gone the rpms fly high, and the car won't move.
Need more info to figure this one out.
Old Aug 27, 2007 | 09:07 PM
pat7755's Avatar
My wheels are fairly new but I started noticing this weeks after. When shifting it is sometimes difficult to get into first gear or reverse. How would I know if it is my clutch going bad?
Old Aug 27, 2007 | 09:12 PM
ouTTie914's Avatar
How long have you had your TT?
Old Aug 27, 2007 | 09:15 PM
pat7755's Avatar
Ive had it about a year but its been on the road for about 3 months.
Old Aug 27, 2007 | 09:19 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: pat7755
If you swapped to a taller wheels or tires and just not notice it? If you smell burning after you drive, your clutch is being roasted and starting to give.
Old Aug 27, 2007 | 09:21 PM
ouTTie914's Avatar
Well, what's your shift point? At what rpm do you change gear, normally.
Old Aug 27, 2007 | 09:22 PM
pat7755's Avatar
Normally at around 25-30k
