High RPMS
Old Aug 27, 2007 | 09:26 PM
ouTTie914's Avatar
Default RE: High RPMS
So what makes you think changing gears has something to do with the high rpms?
If it's only reverse and 1st you're having a problem with.
Old Aug 27, 2007 | 09:32 PM
cincyTT's Avatar
I'm make believe
i wish i could rev to 8000rpms and your reving to 30,000rpms? THATS AMAZING!!!
Think we just found your problem
Old Aug 28, 2007 | 10:10 AM
Wintermute's Avatar
ORIGINAL: pat7755
Normally at around 25-30k
Are we talking about a 747?
Old Aug 28, 2007 | 10:43 AM
WishIWasRWD's Avatar
I'm pretty sure that either your tach is messed up, or you're just retarded. Not trying to be mean here, but unless your description is lacking some important details, there is no other explanation (Aside from a smaller wheel/tire height).
If it were your clutch, it would be a spike (probably when you hit boost), not a steady (for example)500rpm increase.Which would shoot up until you let off the gas. (not what you are describing)
The only possible explanation, other than you smoking way too much weedis that someone replaced your 5 speed with a 6 speed while you weren't looking. If that's the case, try shifting into 6th.
Problem Solved!
Kembal
Jan 10, 2013 10:01 AM
edepaolo
Jul 9, 2010 03:55 PM
Project
Mar 31, 2008 07:54 PM
225tt
Nov 24, 2007 03:00 AM
Dudek12
Sep 29, 2005 08:00 PM
