How Much Would You Expect To Pay For...
Old Mar 6, 2008 | 12:16 PM
exTTreme's Avatar
Default How Much Would You Expect To Pay For...
Just wondering how much you guys would expect to pay for a shop to do the following work on a 2001 225hp TT.
New connecting rods, Instalation of a new preassembled ready to go head, intake manifold installation, Turbo kit installation
FMIC/meth injection kit installation, Clutch/pressure plate/flywheel install, Exhaust install.
I would be supplying the shop all neccasary parts/gaskets for the install so just looking at labor cost, unfortanately I only have one shop to choose from because both the Audi custom shops turned down the job because im not using parts that they are dealers for.
If you guys could throw out some prices that would be reasonable for this work I would appreciate it I plan on doing the work myself if they try to charge me to much.
Old Mar 6, 2008 | 12:34 PM
turbo kraut's Avatar
Tech Guru
Default RE: How Much Would You Expect To Pay For...
do it yourself, will save you the most
Old Mar 6, 2008 | 12:35 PM
cincyTT's Avatar
I'm make believe
I wouldguess about $2k. Lots of that stuff will be done together. You might want to do some of that stuff yourself or with friends. fmic and w/m can be installed yourself.
Old Mar 6, 2008 | 12:46 PM
Red_sapphire89's Avatar
I pmed a member about this not too long ago im not gonna say his name just because i dont know if he wants me putting this out there or not but he payed 3400 for the apr stage 3+ rods and brakes
Old Mar 6, 2008 | 02:51 PM
beachchair's Avatar
ORIGINAL: Red_sapphire89
I assume Labor Only?
Old Mar 6, 2008 | 03:00 PM
yes labor only
Old Mar 6, 2008 | 04:12 PM
Tech Guru
so 8 grand..... including kit
hope they used lube
Old Mar 6, 2008 | 04:35 PM
cincyTT's Avatar
I'm make believe
yes labor only
Then it will be about $4k then at the same shop. Subtract the brake job for a clutch job and that will make up the differnce.
That is assuming that the engine was pulled for the rod install. Also not counting in the w/m injection since that should be installed and tuned by owner.
Old Mar 6, 2008 | 08:40 PM
yea engine was pulled for the install...
Old Mar 6, 2008 | 09:02 PM
cincyTT's Avatar
I'm make believe
Then depending on labor hr rates, it should be $4k give or take $500
