HUGE PROBLEM
Old Feb 7, 2008 | 05:51 PM
Red_sapphire89's Avatar
Default RE: HUGE PROBLEM
how do i use hvac to monitot the battery?
Old Feb 7, 2008 | 05:57 PM
eliTTe's Avatar
ORIGINAL: Red_sapphire89
x2 lol
Old Feb 7, 2008 | 06:20 PM
vegastt's Avatar
They only way I figure checking your volts are on channel 18 in HVAC.
Thats for voltage from your blower. I figure the volts are the same throughout the car so if the vots on the blower are 12-12.5
then your ok.
Old Feb 7, 2008 | 07:13 PM
tom1222's Avatar
because if the clutch is dead i can't go anywhere to charge up the battery like a normal person would do
Exactally my point! Why would you need to go anywhere with a dead clutch regardless if the battery is dead
or alive [&:]
Old Feb 7, 2008 | 07:15 PM
ORIGINAL: vegastt
then your ok.
huh channel 18 are you talking about with a vag tool?
Old Feb 7, 2008 | 07:56 PM
achTTung's Avatar
A normal person would attach a battery charger to the battery, and if they couldn't get the charger to the battery, they'd remove the battery, and take it to a charger.
Old Feb 7, 2008 | 10:35 PM
vegastt's Avatar
No vag com needed.
Toopen up HVAC channels
Press the recirculation button and up at the same time.
then the red temp screen will change to a 1 "channel 1".
Use the temp controller to change channels left or right.
theres like 80 different channels to monitor through HVAC.
Check ross tech's website for all the channels.
Old Feb 7, 2008 | 11:02 PM
  #18
Where on ross tech im lookin can't find anything?
Old Feb 8, 2008 | 02:47 PM
  #19
MeanAudiA6's Avatar
YOU GUYS he cant use the HVAC at all if the battery is dead come on you need a jump start at least to get enough power to even to turn the car accessory on. from there see if you can start the car and rev to like 2000rpms and while doing this hold down that button in climate control area that looks like a bent pointed arrow and the up arrrow and then use that up arrow to go to channel 18 or whatever the guy above me posted
Old Feb 8, 2008 | 02:59 PM
  #20
yea i did that its all good now....but what do all those channels do i cant find meanings on rosstech
