I guess my forge splitter is bad, anything else to try?
Old Jul 25, 2007 | 09:03 PM
carguytt987's Avatar
Default I guess my forge splitter is bad, anything else to try?
Well it is official if I put the DV in the way it is pictured on the forge website and as advised by Cincytt, horn facing forward,charge on bottom port, I can only hold 10-12 PSI? I have went to 13 clicks as suggested and in 2-3 click increments till it is at the last click. It sounds great but...low PSI> Now if I flip it it will hold much higher , I see my 19-20 PSI peak ( however it doent seem to adjust down much, in this position?)so something must be wrong with it . I am tempted to pull it apart and see but I will try to call forge tomorrow, I can stick my finger inside and move the plunger it doesnt seem to bind or anything. Any other suggestions?
Old Jul 25, 2007 | 09:05 PM
achTTung's Avatar
Default RE: I guess my forge splitter is bad, anything else to try?
You have the right spring in it?
Old Jul 25, 2007 | 09:07 PM
cincyTT's Avatar
I'm make believe
there is only one spring. It takes some time to adjust it. Most seem to have better luck moving it directly over the pressure. Elitte had a bitch of a time installing it and finally got his to work. He would be a better person to ask.
Old Jul 26, 2007 | 02:05 PM
WOW!! I called Forge today and talked to a very nice guy, we went through the steps I have taken He thinks it is bad, So he is shipping me another one with a retun label to send back my bad one. I was a little suprised, I figure he would want me to ship mine back then ship me one, I guss customer service does still exist. I would buy from based on this alone , I'm a very happy camper. I'm sure this one will be fine.
Old Jul 26, 2007 | 02:15 PM
.clipse's Avatar
SoCal Crew Member
^ ya forge has awesome customer service. i told them about my forge 004 problems and they sent me a tuning kit and stiffer secondary spring. for free
Old Jul 26, 2007 | 02:16 PM
cincyTT's Avatar
I'm make believe
they take the time to answer ?'s and most of there products have a lifetime warrenty.They cetainly make sure theircustomers are happy.
Old Jul 26, 2007 | 02:55 PM
eliTTe's Avatar
I'm glad you got it straight, I figured something was not right with it.
xNickx
Apr 28, 2015 03:27 PM
czabelin
Aug 30, 2008 04:04 PM
vegastt
Sep 4, 2007 12:18 AM
DiscoStu9
Aug 13, 2007 04:39 PM
andrew.bator
Jun 16, 2007 12:35 AM
