IAT logs on Tcarbon FMIC w/misters
#41
RE: IAT logs on Tcarbon FMIC w/misters
ORIGINAL: DurTTy
im curiosu how will the BM correct pressure loss?
i understand that if i get loss of pressure i up the requested boost, but if that requested boost has to be upped will that not put more stress on the turbo and the complete system?
#42
ORIGINAL: neur0tic
Ya know... I wish someone on here had the forge that could do some IAT logging too. I logged some data with and without the W/M going for IAT... and I was sitting at like 50* at the light.... and got down to like 14* with w/m on ... at full throttle.
#43
ORIGINAL: cincyTT
He wants you to up the boost. So the boost guage and engine sees 20psi when the turbo is really pushing 23-25psi. The requested boost will be the same, the actual will be low, the only way to correct that is to increase the boost with a boost controller since a n75 wont be able to do that.
ORIGINAL: DurTTy
ok so touching on that point, i should jsut eliminate the n75 completely and run my BM ... btw overpriced as it may be the modshack BM is really nice gotta give steve credit for reading some website and building it for us ( not like its original material but still).
i was reading the site that stevo was basing his BM on and they indicated that without the N75 boost was very spiky and unprecdicatable,...
is any1 running BM/BC without the n75.. would like to know.
holy f$#$ i aplogize if im incoerent but 12 beers does that to you ..
#44
ORIGINAL: DurTTy
#48
if you do that, you have to plug the intake if your still running the stock (style) tip. But just aslong as its still pluged into the ecu, it wont have a fit.
